Old 09-07-2012, 08:08 PM   #1
driver01
Drives: brz 13
Delete
Delete
driver01 is offline   Reply With Quote
Old 09-07-2012, 11:05 PM   #2
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by driver01 View Post
I just purchased a new set if the gold Advan TCII for my Raven FR-S.
The center bore is 62mm according to my ruler. I cannot find this hub rings anywhere! Apparently they are not common at all. short of having a set custom made, anybody can shed some light?
I've found 60mm and 64mm rings. Are you sure your measurement is correct? Maybe you could take your wheel to a shop to be measured with the right tool.
Phaedrus29 is offline   Reply With Quote
Old 09-08-2012, 06:23 PM   #3
chutrain
chutrain's Avatar
Drives: WRB BRZ
Which part of the centerbore are you measuring? Some are slightly tapered at the edges.
chutrain is offline   Reply With Quote
Old 09-08-2012, 06:25 PM   #4
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
You need a 62.5 to 56.1 this is a common size.
Spartan65 is offline   Reply With Quote
Advan TcII 5x100 17x8.5 w tires boostin serge Wheels and Tires 9 01-29-2013 01:08 AM
Super limited qty Advan 17x8.5 TCII Stav Canada Classifieds 5 08-22-2012 10:39 PM
Super limited QTY ADVAN TCII 17x8.5 +45 Stav Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-20-2012 07:28 PM
Wheel Hub Bore Size feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2012 12:01 AM
