Old 10-24-2012, 11:37 PM   #1
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
Quest regarding using both stock at 17x8
Im thinking of getting the Enkei 17x8 RP03 with new tires... and use them when i go driving in the mtns or hanging out.. i also want to keep the stock rim/tires for long term and occasionally swap the stockers back if i go driving for 1000+miles or whatever.....or should i ? i may eventually sell the stock tires/rims but i sorta like the idea of keeping the stock setup justin case..
so question is - if all i am doing is going wider --
do i need to get an alignment when the new tires are put on ?
if so, will i mess up things when swapping around the 17x8 and 17x7 throughout the year ??
sorry, im bit of a newbie when it comes to tire mods.. etc etc
any insight would help me decide or forget it and just sell the stockers and not worry about it -- ???
rikdrt1 is offline   Reply With Quote
Old 10-25-2012, 07:22 AM   #2
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
No need for an alignment when changing wheels/tires. Assuming you keep the diameter stock all of the alignment settings will be unchanged. I do it all the time. You will get used to the TPMS light on whatever wheels don't have the sensors. Not a biggie.
celica73 is offline   Reply With Quote
XXR 527 17x8.25 +35(front) 17x8.25 +25(rear) and 1 inch drop AGM6789 AUSTRALIA 17 11-10-2012 05:10 AM
My quest for a BRZ in China is over! Godzpeed Other Vehicles & General Automotive Discussions 9 08-13-2012 05:17 AM
17x8 +35, will it rub? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-31-2012 03:26 AM
Any vendor have in stock rpf1's in black 17x8 +45 offset? track_warrior Wheels and Tires 0 06-25-2012 01:57 PM
New Quest to find legendary 1977 StarWars Celica WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 6 09-29-2011 09:56 PM
