Old 10-24-2012, 11:55 AM   #1
benlevy3
Drives: FRS
Broken Bolts changing control arm!
I was replacing the rear control arm (and putting in coilovers) and broke a bolt. Another one stripped a bit. Both of these happened while I was torqing them down!
Parts on order through Toyota! 3 to 5 days! Anyone know of suitable replacements?
Scion Part numbers:
SU003-02781
SU003-02804
benlevy3 is offline   Reply With Quote
Old 10-24-2012, 12:05 PM   #2
chutrain
chutrain's Avatar
Drives: WRB BRZ
Check Subaru dealership as well.
Which bolt was it and any pictures?
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 10-24-2012, 12:13 PM   #3
Prez
Drives: accord
Prez is offline   Reply With Quote
Old 10-24-2012, 12:16 PM   #4
benlevy3
Drives: FRS
Called Subaru. Noting in stock either.
The scion guy sent me the parts diagram. That was really nice.
Basically, the bolt that connects the rear control arm to the wheel hub (not sure of real term for that assembly) and the bolt that connects the sway bar to the control arm.
Going to bring the bolts in to Fastenal and see if I can get a temporary replacement.
Old 10-24-2012, 12:17 PM   #5
benlevy3
Drives: FRS
Originally Posted by Prez View Post
Where did you get that picture of me from?
Old 10-24-2012, 12:46 PM   #6
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Scion Part numbers:
SU003-02781
SU003-02804
Were you using a torque wrench to torque them down, or something else?
Ranatsu is offline   Reply With Quote
Old 10-24-2012, 12:54 PM   #7
chutrain
chutrain's Avatar
Drives: WRB BRZ
Surprising that both the bolts broke. Were you using an impact gun or something?
In the garage:
1988 BMW E30 M3
Old 10-24-2012, 12:57 PM   #8
benlevy3
Drives: FRS
Yes I was using a torque wrench. The first thing I did was double check the settings. Ratchet type torque wrench.
I will say that I did remove the bolt twice, but still it should not have snapped. I did have to persuade it out (lightly with a hammer).
This should not have happened! I think the tourqe specs are only 59 foot pounds. (dont have it here in front of me).
Old 10-24-2012, 01:10 PM   #9
chutrain
chutrain's Avatar
Drives: WRB BRZ
I removed mine by hand, and used a hammer with a block of wood to persuade out. I did notice that bolt had a brittle feeling. Not sure if that makes sense.
In the garage:
1988 BMW E30 M3
Old 10-24-2012, 01:51 PM   #10
benlevy3
Drives: FRS
Originally Posted by chutrain View Post
I did notice that bolt had a feeling. Not sure if that makes sense.
Will you share those mushrooms please!
Do you think I hurt is's feeling's by hitting it with a hammer..
Old 10-26-2012, 12:18 AM   #11
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
This place called the Internet.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 10-26-2012, 12:26 AM   #12
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Why were you replacing the control arm?
chulooz is offline   Reply With Quote
Old 10-26-2012, 07:02 AM   #13
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Any chance some of the control arm bolts specify turning the bolt rather than the nut? That was the case on my '00 Celica.
celica73 is offline   Reply With Quote
Old 10-26-2012, 05:55 PM   #14
deucethemoose
Nah, typically if that were the case the nut would have a tab welded on that would lock it against the control arm, which it does not. They're just a standard bolt and nut - shouldn't be too difficult to just buy a grade 10 bolt in the right size and throw it in. No need to go to the dealer for something like that, unless you like spending an absurd amount of money for what you can score at a hardware store.
Crash bolts alignment change ABQautoxer Tracking / Autocross / HPDE / Drifting 39 03-24-2014 05:45 PM
Where to buy Whiteline Camber Bolts whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-26-2013 02:05 PM
Another crash bolts alignment thread jeebus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 10-28-2012 12:29 AM
seat bolts? zooki Cosmetic Modification (Interior/Exterior/Lighting) 3 08-29-2012 06:00 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
