Old 10-21-2012, 04:49 PM   #1
Stressin
Stressin's Avatar
Drives: GT86
Down on power after reflash
Just about to have my ecu reflashed, is it true that you lose power and has anyone confirmed this on a dyno?
Stressin is offline   Reply With Quote
Old 10-21-2012, 05:42 PM   #2
Lonewolf
Lonewolf's Avatar
Drives: Moped
No one seems to know with any certainty...all we have so far are "seat of the pants" butt dyno impressions which have no data to back up the feelings...
Old 10-21-2012, 06:03 PM   #3
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
Are you referring to the reflash that fixes the CEL issue?
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 10-21-2012, 06:13 PM   #4
Rob_g
Drives: 2010 4Runner Trail
I'll go on record and say I don't think this is true. I have a new ECU in my FR-S and it doesn't seem 'down on power'. Although it still does not idle well and seems to now have some kind of random throttle glitch or bog condition at low rpm.
Rob
Rob_g is offline   Reply With Quote
Old 10-21-2012, 08:35 PM   #5
wallace03
wallace03's Avatar
Drives: WRB BRZ
I was also wondering about this. Will the new cars off production line with the new ECU be less responsive? Didn't someone on the forums say that they saw improvements after resetting their battery after getting the new ecu?
wallace03 is offline   Reply With Quote
Old 10-21-2012, 09:31 PM   #6
Tricky1980
Drives: 2013 Raven Fr-s
for the most part I think its the exact same before and aftrr'.... My issue is about 5% of the time I have a real bad bog and lack of acceleration down low from stop or almost stop...def no slow rolling start in 2nd gear......
Tricky1980 is offline   Reply With Quote
Old 10-21-2012, 10:16 PM   #7
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
sorry to here i hope i dont get these horrid issues when mine comes in
i hope toyota and subaru really do some heavy duty glitch fixes
DanoFA20 is offline   Reply With Quote
Old 10-21-2012, 10:28 PM   #8
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Immediately after a reflash, the car will be down on power and feel sluggish. That's because the reset of the ECU will clear the learned values, so the ECU will be using a known safe calibration. As you drive it, the gas pedal will get sharper and the power will return. I haven't done this with my BRZ yet, but my STI behaves the same way and it takes about 20 miles or so for it to feel normal again.
Old 10-21-2012, 11:25 PM   #9
wheelhaus
wheelhaus's Avatar
During my audio installation I had the battery disconnected, and after I'd finished and reconnected the battery, throttle response was quite noticeably sluggish. After some miles (maybe 50-100mi?) it began to feel like normal again. I don't believe this was any sort of placebo or me "getting used to the machine" because I noticed for the same amount of foot movement the throttle responded more quickly and accurately, as it did before.
I say give it some time and some miles (including some full rpm runs through the gears) to allow the ECU to learn and adjust it's parameters again.
wheelhaus is offline   Reply With Quote
Old 10-21-2012, 11:31 PM   #10
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
resetting the battery after a new ECM is replaced will have no effect due to no learning values being stored in the ECM. one thing i can tell you is drive it like it new (may not want to pass 4k RPM's) because the ECM will learn normal driving habits and this is good because when you get on it the ECM will know your in a panic and give more performance.
:happy0180:
20valvewynn83 is offline   Reply With Quote
Old 10-22-2012, 12:02 AM   #11
dabocx
dabocx's Avatar
Drives: Scion FRS
Hopefully it does go back up to normal levels, because if it doesnt it simply is not acceptable. Im still trying to get my idle dip fixed and the last thing i need is for it to get fixed and for this to happen permanently
dabocx is offline   Reply With Quote
Old 10-22-2012, 01:23 AM   #12
Those Meddling Kids
Drives: 2013 SWP BRZ limited
If I get a chance this week I will throw mine back on my dyno and verify power. It feels around the same I think.
Those Meddling Kids is offline   Reply With Quote
Old 10-22-2012, 02:22 AM   #13
Le86
Drives: Asphalt FR-S
You're gonna have a long wait if you have the same issue I did, my friend. Dealer tried to reflash my ECU but no dice. My car has been rotting at the dealership for the last 3 weeks, awaiting a new ECU to arrive.
10/01/2012 FR-S down for P0019 code. Received vehicle back from dealership with a new ECU 10/30/2012
Le86 is offline   Reply With Quote
Old 10-22-2012, 07:37 AM   #14
dabocx
dabocx's Avatar
Drives: Scion FRS
FA20CLUB.com Stage 1,2 & E85 ECUTEK Reflash SALE FA20Club.com Engine, Exhaust, Bolt-Ons 196 03-23-2013 09:37 AM
FA20CLUB.com ECUTEK Reflash Installed.....WOW msile Engine, Exhaust, Transmission 50 02-27-2013 08:58 PM
FA20CLUB.com Stage 1 ECUTEK Reflash SALE FA20Club.com Engine, Exhaust, Bolt-Ons 52 09-23-2012 08:30 PM
FA20CLUB.com Stage 1 ECUTEK Reflash Results FA20Club.com Engine, Exhaust, Transmission 20 08-25-2012 07:02 PM
Estimated HP gains - bolt on mods and reflash? ahausheer Engine, Exhaust, Transmission 207 01-14-2012 06:14 AM
