Old 10-19-2012, 11:48 AM   #1
mrha
#1819
mrha's Avatar
Drives: Lightning Red Subaru BRZ
Stock dampers on the BRZ are made by Showa. Same for FRS?
When I lowered my car I noticed the stock struts were made by Showa which as many of you know produces the suspension pieces for Spoon Sports etc. I was more than pleasantly surprised when seeing this.
Then I read the BRZ and FRS have different dampers between the two. Are the FRS struts made by Showa as well?
mrha is offline   Reply With Quote
Old 10-19-2012, 11:53 AM   #2
Racecomp Engineering
Many of us (RCE, eibach, I think dwx) have tested the two shocks to be essentially identical. Yes both made by showa and pretty good for an OEM strut .
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
avusblue (10-19-2012), mrha (10-20-2012)
Old 10-19-2012, 11:57 AM   #3
D1cker
Drives: B9 S4/ND2
I believe the dampers to be the same, just the spring rates are different.
D1cker is offline   Reply With Quote
Old 10-19-2012, 12:08 PM   #4
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
Showa also makes the oem s2000 dampers Not surprised Toyota/Subaru turned to them for the stock setup
GTM_Challenge is offline   Reply With Quote
Old 10-19-2012, 12:09 PM   #5
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
They also make AWESOME motocross suspension.
No Limit Motorsport is offline   Reply With Quote
Old 10-19-2012, 01:07 PM   #6
chutrain
chutrain's Avatar
Drives: WRB BRZ
Surprised they used Showa. I would have thought they would go with something lower end
like the KYB or Tokicos.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 10-19-2012, 01:25 PM   #7
04-07 STI used to be KYB and they switched to showa for 08+ STI. Those were a big improvement over the KYBs. When Subaru wants a decent quality sporty shock that's what they use now and we're glad. And of course Bilstein japan for special edition stuff.
- Andrew
Old 10-19-2012, 01:28 PM   #8
RYU
RYU's Avatar
Drives: really slow...
- Andrew
Agree!
Andrew - Have you guys heard of Koni or Bilstein making a set for our car? I liked my 3 setting adjustable (rebound only) Konis on my S2k before.
RYU is offline   Reply With Quote
Old 10-19-2012, 01:31 PM   #9
Turn in concepts will be testing koni yellows with our RCE yellow springs very soon.
- Andrew
Old 10-19-2012, 01:32 PM   #10
chutrain
chutrain's Avatar
Drives: WRB BRZ
I believe Koni is in the process and should have something in the next couple of weeks. Hope Ground Control will have something with a pairing with Konis.
In the garage:
1988 BMW E30 M3
Old 10-19-2012, 01:44 PM   #11
GTM_Challenge
Drives: On track
I've heard the initial konis will be inserts...
If I talk to Lee at Koni again soon, Ill try and get as much out of him as I can. Might not be until SEMA though - which by then they will probably have the product announced already.
Old 10-19-2012, 01:50 PM   #12
xwd
It's around in other threads, but GC has a setup paired with Koni inserts coming out very soon. It's basically a coilover since they are using their own front strut housings with the Koni inserts and their sleeve kit. Showa is a big OE manufacturer for lots of brands.
There was a Koni thread within the last couple days, they are definitely working on things but the fronts will be inserts.
Old 10-19-2012, 01:51 PM   #13
I'd be surprised (but happy) if koni do anything other than inserts for the front. Bilstein will eventually have something but they take a while. We are going to push them.
- Andrew
Old 10-19-2012, 02:22 PM   #14
RYU
RYU's Avatar
Exciting updates! I personally would love something with some rebound adjustability. Not too much ask right?
GT86 springs on FR-S dampers? jm1681 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 10-01-2012 12:36 PM
AST Dampers just arrived! Matt Andrews Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 09-20-2012 03:11 PM
Which Dampers to get? djliquidsteele Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 08-27-2012 02:13 PM
OE Replacement Dampers Sccabrz192 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-08-2012 11:52 AM
