Old 10-13-2012, 10:35 PM   #1
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Remove dry wax?
In the bottom of the grill i have dried wax in the corners on the holes. How do i remove this since my fingers/ a rag dont fot?
lbroskee is offline   Reply With Quote
Old 10-13-2012, 10:52 PM   #2
DIM
Try a toothbrush. That's what I use in hard to reach areas.
DIM is offline   Reply With Quote
Old 10-13-2012, 10:59 PM   #3
lbroskee
lbroskee's Avatar
Thatll work on month old dry wax?
Old 10-13-2012, 11:00 PM   #4
mashal
DADA
mashal's Avatar
Drives: 2013
Iso and some acid brush
I-Tapatalk
mashal is offline   Reply With Quote
Old 10-13-2012, 11:06 PM   #5
Paul_S
Drives: red
Does your wife have one of those little household steamers ? Steam will do the trick without leaving scratches. I use a commercial VX5000 but one of those little teapot type steamers will do the trick.
Paul_S is offline   Reply With Quote
Old 10-13-2012, 11:52 PM   #6
lbroskee
lbroskee's Avatar
no, im only 22. me and my roommate dont even own an iron lol. ill try the toothbrush 1st and hope its that simple
Old 10-14-2012, 02:19 AM   #7
einzlr
Drives: several
Also try q-tips. If you're still not having any luck, go to a well-stocked auto supply store and look for a tool especially designed to get into small corners. It looks like a thick pencil with a rubber tip at one end and a soft brush at the other.
And to avoid a repeat, modify your waxing technique. For those areas use instant detailer or one of the modern spray-on waxes that don't leave residue. Or if you want to stick with paste wax, then don't apply it directly but instead use what's left on the rag after applying and rubbing off the main panels.
Oh, and yes, it will work on old wax. Wax breaks down with time, particularly if exposed to UV rays. That's why it is necessary to re-wax frequently
einzlr is offline   Reply With Quote
Old 10-14-2012, 04:00 AM   #8
goat_cheese
Drives: R33
91% ISO Prop alcohol and light agitation, be sure to reprotect after.
goat_cheese is offline   Reply With Quote
Old 10-14-2012, 09:06 AM   #9
whaap
whaap's Avatar
Toothpicks can also be handy in certain situations.
whaap is offline   Reply With Quote
Old 10-14-2012, 09:28 AM   #10
markitect
Drives: Scion FRS
Wd40 on a brush is good for taking off wax
markitect is offline   Reply With Quote
Old 10-14-2012, 08:25 PM   #11
David-Fermani.com
David-Fermani.com's Avatar
Drives: Dirty
Unless you know what you're doing, I wouldn't suggest using a brush! Just try using some All Purpose Cleaner and/or some Alcohol with a soft towel and only use soft pressure allowing the product to soften and dissolve the reminants.
Metro Detroit's Leader in Vehicle Preservation & Perfect Paint Finishes
Official Optimum Opti-Coat PRO Application Specialist for Metro Detroit
David-Fermani.com is offline   Reply With Quote
Old 10-14-2012, 08:38 PM   #12
lbroskee
lbroskee's Avatar
it's on black plastic, not the paint tho. a brush will still mess that up?
Old 10-14-2012, 08:54 PM   #13
einzlr
Drives: several
It can scratch.
Will u remove the spare tire? Bahraini86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 133 05-06-2019 11:18 AM
How do you remove... frosty86 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 12 10-14-2012 08:23 PM
How do you remove factory antenna? srt4_night_rider Cosmetic Modification (Interior/Exterior/Lighting) 7 08-10-2012 07:37 PM
Anyone know how to remove headlights? Memphis Cosmetic Modification (Interior/Exterior/Lighting) 25 06-12-2012 07:31 PM
