Old 09-26-2012, 10:09 PM   #1
Dzeremijs
Drives: 2013 WR Blue BRZ - MT
Throttle slightly sticking?
Something I have noticed is that when I shift from 4th to 5th, and 5th to 6th at about 3500-4000 RPM, the revs will jump up a couple hundred RPMs almost every time. To make sure it's not just me having a heavy foot and leaving it on the gas before I engage the clutch, I have completely taken my foot off the gas, waiting a split second, then shifted-- and when I do that, the little blip isn't as significant. Does that sound like anything? Have any of you had this happen?
Dzeremijs is offline   Reply With Quote
Old 09-26-2012, 10:33 PM   #2
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
I noticed the same thing a few days ago and did the same exact test. It makes it less significant, but doesn't eliminate it.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 09-26-2012, 10:58 PM   #3
Turdinator
Señor Member
Turdinator's Avatar
Its a electronic throttle thing, i have driven a few cars that do that. I believe the car is holding the throttle open without firing the injectors to burn off any excess fuel for emissions etc.
1974 TA22 Celica
2013 86 GT
Old 09-26-2012, 11:44 PM   #4
Dzeremijs
hm...well it's annoying, but it's good to know its not an issue. Thanks!
Old 09-27-2012, 01:00 AM   #5
Turdinator
Señor Member
Turdinator's Avatar
Tell me about it. It took me a while to learn shift points in the WRX cause of this. I kept hitting the limiter even tho I had let off the throttle in time :-/
1974 TA22 Celica
2013 86 GT
Old 09-27-2012, 10:07 AM   #6
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
oh man..I am going to hate this but i'll be used to it
Old 01-27-2013, 06:26 AM   #7
BunnyRZed
BunnyRZed's Avatar
Drives: BRZ Limited [37J]
It has been annoying but I've noticed this too. I up shift slowly and it blips the throttle even with my foot off the gas. Can someone confirm that this is normal for our car? I've watched youtube videos and it doesn't seem to be doing it but maybe because they are flooring it?
BunnyRZed is offline   Reply With Quote
Old 01-27-2013, 10:32 AM   #8
CA2
Dusty Raven
Drives: FR-S MT
I have the same issue. I first noticed it from the sound -- it sounded like I still had my foot on the gas after engaging the clutch pedal, for a split second (revv'ed up). Really annoying. Been trying to adapt my driving style to avoid it. Glad I'm not the only one! Been driving stick for 15 years and never experienced this before.
CA2 is offline   Reply With Quote
Old 01-27-2013, 10:59 AM   #9
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
Totally normal. AFAIK it's something to do with the type of drive-by-wire used in many toyotas/hondas/subies/mitsu, nissans. My tC did it, my dad's SI does it, my FR-S does it. I actually kind of like it, the extra little throttle input negates some of the RPM drop when shifting aggressively and seems to make the shifts a bit more smooth. In my experience if you're using less than 30% throttle it doesn't happen, so I think it's something baked into the DBW system.
Xinshadow is offline   Reply With Quote
Old 01-27-2013, 12:19 PM   #10
White64Goat
Think I read where the 2014 Corvette has something similar with the 7 speed manual trans and they are calling it 'rev-matching' for better shifts.
Old 01-27-2013, 01:14 PM   #11
BunnyRZed
BunnyRZed's Avatar
I was thinking it might have been the drive by wire, but wanted to confirm, thanks.
Old 01-27-2013, 01:42 PM   #12
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
'Rev-matching' is something 'they' have been calling 'it' for forever. It is simply matching rpm and vehicle speed on shifts. This goes for any vehicle with a clutch (sports car, bike, big truck, whatever). A newer thing on some cars is something of a throttle hold and a throttle blip. The new VW Beetle sustains throttle for a short period after you take your foot off. This helps with smoother shifting. (I know because my parents have one and I drove it up and down the place.) The throttle blip is where the computer 'taps' the throttle on the downshift. The new 370z has that option.
Old 02-01-2013, 12:39 AM   #13
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
Don't think i would like this type of throttle control... I rather the old cable style... Like on the supra's....
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 02-01-2013, 01:27 PM   #14
frs23
frs23's Avatar
Drives: FR-S H Lava
>>the throttle blip is where the computer 'taps' the throttle on the downshift. The new 370z has that option.
might as well put in a xbox or ps controller
frs23 is offline   Reply With Quote
Anyone having throttle issues? FRiSson Issues | Warranty | Recalls / TSB 13 09-25-2012 05:35 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
Throttle Controllers harajukukei Engine, Exhaust, Transmission 31 07-28-2012 12:40 AM
2014 Cars slightly more expensive? Buggy51 Other Vehicles & General Automotive Discussions 10 02-29-2012 09:24 PM
