Old 09-23-2012, 02:31 AM   #1
Mister_Sir
Mister_Sir's Avatar
Drives: 2013 Scion FRS
Removing Intake Silencer
Has anyone tried this? My friends at a meet disconnected my intake to see what it sounded like. One mentioned removing the silencer from the intake.
Mister_Sir is offline   Reply With Quote
Old 09-23-2012, 02:34 AM   #2
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
Edit: holy crap i cant read
what silencer are you referring to? and do you have a turbo?
Ravenlokk is offline   Reply With Quote
Old 09-23-2012, 02:41 AM   #3
Innova
Drives: 2013 BRZ Limited
I've removed it and plugged up the opening. Unfortunately there was no major sound difference.
Innova is offline   Reply With Quote
Old 09-23-2012, 02:45 AM   #4
Mister_Sir
Mister_Sir's Avatar
I'm not talking about the sound tube. Apparently theres a silencer under the intake box or somewhere around there. Idk A guy was just talking about it.. and no my frs is N/A
Old 09-23-2012, 03:04 AM   #5
Ravenlokk
Ravenlokk's Avatar
Assuming OP is referring to this. And I'm not sure. Got the AIRAID box personally, and love it. Plus the price is great- especially with the $50 rebate!
Old 09-23-2012, 05:42 AM   #6
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'm pretty sure the OP is referring to chamber the projects downward ~90 to where the sound tube comes off. Yes people have removed it. No we don't have anything that's 100% concrete about it's effects. Perrin posted gains of 0 hp when they tested it out. Some have reported no issues, others are reporting issues at high load and low rpm. YMMV
Old 09-23-2012, 12:57 PM   #7
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
I removed that and the sound tube, no difference but a cleaner engine bay really.
Flat Black VW is offline   Reply With Quote
Old 09-23-2012, 01:10 PM   #8
BRZ?
Drives: 2014 SWP 6MT BRZ
Why is this in the Forced Induction forum???
BRZ? is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZ? For This Useful Post:
Ravenlokk (09-23-2012), vubaru (09-23-2012)
Old 09-23-2012, 01:27 PM   #9
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Because removing the Intake Silencer adds boost! and more boost = more powaaaaa.
Tansey86 is offline   Reply With Quote
Old 09-23-2012, 01:41 PM   #10
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Removing the intake silencers can cause issues with the MAF reading the incoming air. One job of the silencers is to counteract resonance from the engine that causes the air in the intake pathway to vibrate. These vibrations can cause the MAF to mis-read the air passing through it. Best to leave them on just in case.
The Following 2 Users Say Thank You to Draco-REX For This Useful Post:
ddevl_86 (03-30-2021), ultra (09-23-2012)
Old 09-23-2012, 02:42 PM   #11
ahausheer
Re-member
Drives: Toyota camry
Yeah leave it on. Google a video of Ferraris new v12. That engine has these weird looking tubes sticking out from the intake for each cylinder bank. They function similarly to the box you have removed in that they aid intake harmonics. The volume of the box on our car is very carefully calculated. It may be there to alter the engine note, but it also likely plays a role in helping the intake cram as much air as possible into the engine. Some engines actually achieve a small supercharging effect from a properly tuned intake.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
The Following User Says Thank You to ahausheer For This Useful Post:
Old 09-24-2012, 11:03 PM   #12
Mister_Sir
Mister_Sir's Avatar
Well I dont see where removing the silencer (a hollow box) would make much more of a difference than changing to a short ram intake as far as air flow goes. I ended up removing it and it actually sounds good. It gives the engine a more growly note when I really get on it. I'm eventually going to get a sri but this is cool for a while.
Old 09-24-2012, 11:08 PM   #13
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
the box is not a silencer, i have no idea who told you this or where they got that info from. For what it really is refer to ahausheer post.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 09-24-2012, 11:19 PM   #14
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
what does this have to do with boost?
jdzumwalt is offline   Reply With Quote
The Following User Says Thank You to jdzumwalt For This Useful Post:
usptwins (09-27-2012)
Removing and Replacing BRZ/FR-S Intake, Air Filter and Noise Generator Delete GrimmSpeed DIY (Do-It-Yourself) Guides 99 01-25-2015 01:24 AM
JDM 86 Rear Seat Silencer ZC6BRZ Cosmetic Modification (Interior/Exterior/Lighting) 28 12-01-2012 09:33 PM
Removing decals sa1126 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 07-12-2012 12:48 PM
Removing pinstriping Zxtole Cosmetic Modification (Interior/Exterior/Lighting) 15 06-10-2012 08:12 PM
Removing the 86 badge on the front of the car Pake1 Cosmetic Modification (Interior/Exterior/Lighting) 1 06-10-2012 08:37 AM
