Old 09-19-2012, 03:26 PM   #1
pastuch
pastuch's Avatar
Michelin X-Ice 3: 215/50R-17
SO the early reviews last winter for the X-ice 3s were pretty stellar. Anyone know if putting them on the stock rims will be an issue?
They don't come in 215/45-17 only 215/50R-17.
Or should I just get X-ice 2s?
pastuch is offline   Reply With Quote
Old 09-19-2012, 03:41 PM   #2
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
I'm going studded Federal Himalaya WS2-SL 215/45R17 $751.80/set - studs/taxes in on stock rims.
Calgary AB. I wouldn't oversize I don't think.
Khyron686 is offline   Reply With Quote
Old 09-19-2012, 03:46 PM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Not sure if I'll go with the X-Ice, but I'm considering 215/50-17 instead of 215/45. That would get an overall diameter 22mm larger than stock. Since I've lowered my car 20mm, getting 11mm back would be nice in the winter.
Old 09-19-2012, 03:51 PM   #4
pastuch
pastuch's Avatar
A few folks in last years winter tire thread argued going a little larger is a good thing for grip. Many were talking of 215/50-17 and it's generally much less expensive than 45R tires.
Old 09-19-2012, 04:27 PM   #5
hyper4mance
hyper4mance's Avatar
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
I went with 215/55 x-ice 3 for the stock rims but haven't mounted them on yet. 55's were a decent amount cheaper since I got them under $570 shipped. According to the tire calculator, the diameter increases 21mm but I think it should be fine. I'll let you know if I run into any issues.
hyper4mance is offline   Reply With Quote
Old 09-19-2012, 05:06 PM   #6
ranisron
Drives: 2013 SWP BRZ Limited #2344
205/55/16 Dunlop Winter Sport 3D on Stock Saabaru wheels... (16x6.5 Enkei wheels)
ranisron is offline   Reply With Quote
Old 09-19-2012, 05:25 PM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
Aaaaand the tires I want don't come in 215/50.. sigh.
Old 09-19-2012, 08:11 PM   #8
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
According to my reference when comparing 215/45R-17 with 215/55R-17, this would mean that when the speedometer reads 100kph the car would be travelling 106.9 kph. Thats relatively quite different.
195/55R-16 gives 100 speedo = 99.3
205/55R-16 gives 100 speedo = 101.1
smbrm is offline   Reply With Quote
Old 09-20-2012, 07:50 AM   #9
hyper4mance
Yep I know the speeds will be off a bit, but they are on the stock 17" rims. For my setup 215/55/17 according to http://www.rimsntires.com/specs.jsp, When speedometer reads 60mph (96.6km/h) actual speed will be 64mph (103km/h): 6.7% faster.
Old 09-20-2012, 10:20 AM   #10
Jayde
Jayde's Avatar
Was thinking of picking up a set of 16s steelies and using 205/55/16s. Any recommendations for tires?
Edit: Yay 1000 posts!
Jayde is offline   Reply With Quote
Old 09-20-2012, 10:46 AM   #11
zex
zex's Avatar
Drives: Subaru WRB BRZ Limited
Was thinking the same way, did a quick search with those sizes and found this General Tire Altimax Arctic, it had good reviews on Canadian Tire and a quick google search.
Any opinions on this?
zex is offline   Reply With Quote
Old 09-20-2012, 01:12 PM   #12
smbrm
smbrm's Avatar
Ok that you accept those numbers, as long as you remember when you start challenging stop light speed on green cameras!
Old 09-20-2012, 06:06 PM   #13
Khyron686
I also thought there was an issue with (diff/abs sensors/??) for more than 5% difference in wheel diameter?
Old 09-20-2012, 11:18 PM   #14
smbrm
smbrm's Avatar
I guess that needs researching? Since all tire diameters would be assumed to be the same, not sure how that effects a torsen LSD? If all tires are the same diameter, how does that effect the ABS? I would have thought both of these are sensitive to the difference between the wheel speed activity relative to each other?
Wheel Directory: OZ Ultraleggera 17x8.0 +48 Mageep Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 104 04-11-2021 12:03 AM
Wheel Directory: BBS CH-R 18x8.0 +38 Racecomp Engineering Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 81 10-01-2014 02:12 AM
FS: 245/40/18 Michelin Pilot Alpin PA3 Snow Tires Chuynh207 Wheels and Tires 3 11-06-2012 01:19 PM
Michelin Pilot Super Sport 17 inch DieselBoXXer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-05-2012 10:17 PM
Why pay Michelin prices? $185 per tire? Try this OE alternative: ExtremeContact DW rogerdalien Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 05-17-2012 01:33 PM
