Old 05-15-2012, 08:21 AM   #1
rogerdalien
Drives: 07 Corolla CE
Why pay Michelin prices? $185 per tire? Try this OE alternative: ExtremeContact DW
http://www.tirerack.com/tires/tires....DWXL&tab=Sizes
Significantly cheaper, a higher performance category, great reviews, very slightly lighter, many tire sizes to consider if you don't want OE size of 215/45/17. Try 215/50/17?
rogerdalien is offline   Reply With Quote
Old 05-15-2012, 08:24 AM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Even better are star specs for a little more but still a lot less than OEM
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Last edited by Dave-ROR; 05-15-2012 at 09:55 AM. Reason: edit: fixed post, I didn't click on the link.
Old 05-15-2012, 08:54 AM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Even better are star specs for even less
The Star specs are $25 more per tire.
The Continental ExtremeContact DW tires are excellent summer daily tires. Great grip, quiet, and excellent wet traction. I would not hesitate to (and have) recommend them to someone looking for a comfortable tire that performs. Another benefit, for some, with the ECDW is that it has rounded shoulders; it isn't a very "square" tire. So it will fit under fenders better at extreme offsets/sizes.
The only downside is that the ECDW has rather soft sidewalls. If you want a sharper turn-in and higher grip, are you're willing to sacrifice comfort and have average wet traction then the Dunlop Direzza Z1* Spec is the way to go.
I've had the ECDW on my spec.B and loved them. But I'm going to put the Z1* on my BRZ. Unless I go with a 245/35-18, then it has to be the Kumho Ecsta XS.
Old 05-15-2012, 09:55 AM   #4
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Err I didn't click on the link, thought he was saying the Contis were 185/each. Either way, I'd rather have star specs. The EC DWs are good tires, but I prefer star specs more. And Ad08s even more (although you pay ~OEM prices for them). RE11s are great in the rain but I prefer the AD08s to those also.
Actually I think AD08s are my favorite tire at the moment
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-15-2012, 10:06 AM   #5
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Originally Posted by rogerdalien View Post
... many tire sizes to consider if you don't want OE size of 215/45/17. Try 215/50/17?
Are you being a shill or are you actually trying to help? Do you have direct experience with both the actual OEM tire and the Conti DW to make such a proclamation as the Conti DW being an "OE alternative"? What qualifiers or properties let you conclude as such?
The Conti DW is not in the same tire class as the OEM tire. Just from that facet right there, it cannot be an "OE alternative". If you meant to say "Hey, I like this tire and I think it'd work out well for my application", then cool. Otherwise, you're being misleading. Throwing out random tire sizes with no qualifying factors doesn't help either.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 05-15-2012, 10:08 AM   #6
df.dima
Drives: FR-S and Mazda 3 Sky
Excuse me for my unfamiliarity with these "performance" tires and RWD platform, but what would be a good guess on how many miles can we get out of any of the above mentioned tires? Obviously stickier will probably be less mieles generally speaking, but what is a general consensus?
I was looking at these two as well, plus there's some talk about new BFG Sport Comp 2 on miata forum that just became recently available at TR.
I'm trying to figure out what would be the right tire in terms of daily driving for wear/performance. I mean if I get 10k or less on a set of sticky tires just going to work and weekend driving, screw that!
df.dima is offline   Reply With Quote
Old 05-15-2012, 10:11 AM   #7
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'm currently at about 15k miles on my AD08s with about 40% left up front and 70% left in back.. need to rotate them.
I also run a fairly agressive alignment, track and autocross with the tires. Just one track day on those though and about 8 autocrosses.
Tire life greatly varies based on alignment, inflation and driving style. I don't push my cars on the street, don't do burnouts, don't stand on the brakes, etc. For autocross I'm 10/10ths but that's not a lot of miles..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-15-2012, 10:22 AM   #8
df.dima
Sounds pretty reasonable. Thanks for the info. My wife would not approve tire changes very often .
Old 05-15-2012, 10:38 AM   #9
Draco-REX
Corner Junkie
Draco-REX's Avatar
If you're not going to be AutoXing or going to track days regularly, the ECDW would likely be a great choice for you. The only problem you might encounter is the ECDW is prone to cupping on the outside tread if your alignment is off. Keep your alignment square and they'll work great for you.
I'm not familiar with the Comp2 but it is a performance grade below the ECDW (according to TR). I have used the ECDW and can attest to its behavior personally.
Oh and the ECDW has a treadwear rating of 340 which, while not *directly* comparable to another manufacturer, it still going to be much better than the 140-180 you'll see in Extreme Performance tires.
Old 05-15-2012, 10:54 AM   #10
df.dima
Yea thanks. I know that ratings can't be compared across mfgs.
Old 05-15-2012, 01:35 PM   #11
Ryephile
Hot Dog
Ryephile's Avatar
Just in case you didn't know, the UTQG ratings were intended to provide reasonably comparative data between tires. In reality though, the UTQG's are merely a loose guide of approximate performance in regards to treadwear, wet braking, and high speed temp resistance.
As always, the Tire Tech section on Tire Rack's website is excellent:
http://www.tirerack.com/tires/tirete....jsp?techid=48
Put simply, a treadwear of 100 means the tire should last 7,200 miles. The Michelin Primacy HP's that are standard on the FR-S/BRZ have a treadwear of 240, so they should in theory last 17,280 miles. Obviously, your mileage may vary based on inflation pressures, load, alignment, and driving style.
Old 05-15-2012, 02:33 PM   #12
dsgerbc
Drives: BRZ(sold), STI
DW are good DD tire. Enough dry grip to shorten braking distance in emergency and lot's of wet grip for safety (and I think some rich autox-ers used them as a dedicated rain tire in the past few seasons). However, mine do make some humming noise @80mph.
dsgerbc is offline   Reply With Quote
Old 05-15-2012, 03:01 PM   #13
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
Other good lost cost options are Hankook Ventus V12 Evo K110 and the Nitto Invo
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 05-15-2012, 04:31 PM   #14
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
My lord this car is going to be cheaper to skin than my trucks. Both of those cost over 1k for 4 tires.
This car is going to be soooooo cheap to operate, it makes me giddy!
michaelahess is offline   Reply With Quote
Alternative to the 2012 Civic SI? D4ng3r Other Vehicles & General Automotive Discussions 11 04-08-2012 04:52 PM
Continental ExtremeContact DW, experiences? #87 Other Vehicles & General Automotive Discussions 5 03-09-2012 10:58 AM
SoCal, BRZ GB alternative dealer Subaru Irvine. wu_dot_com Southern California 4 02-20-2012 05:44 PM
