Old 09-14-2012, 04:42 PM   #1
gmookher
Perrin Oil Cooler -Prototype, Installed today!
See for yourself
Easy breezy install, tricky part for me was getting the lamps out of the fenders, the rest was cake.
you can see the sound tube delete if you look closely in one of the pics
also in another pic you can see the moroso aos
I'm digging the sound of the header back perrin stainless system (new thread in the works!)
this oil cooler was in the same box, and was lucky to get to try it and install it as a test subject, no instructions were given...and I did fine. I think I may have put the bolts in for the oil cooler upside down but it really didnt matter. Chris was a phone call away if I needed help, and I took him up on it, just one time for tech, and another to confirm the clampless oil hose, neat stuff
gmookher is offline
Old 09-14-2012, 04:48 PM   #2
RYU
RYU's Avatar
Drives: really slow...
Is that heat exchanger mounted in your pics?
I wish it wasn't right smack in the middle. Us 6AT guys also need room for a Trans Cooler.
RYU is offline
Old 09-14-2012, 04:48 PM   #3
gmookher
I was surprised that the mocal fittings and hose were clampless, but its true, thats how its done
Even after Chris told me I was skeptical, but its 100% kosher
In one picture you can see the factory subaru pipes against the wall
in another you can see my other toy, a land rover discoery 2 thats used as a trail leader rig in moab where I volunteer for a national rover club as a trail guide, means pulling and recoveries, its also nicely modded out, lifted , locker front rear and center, etc etc
sorry for the sizes, but the resolutions for your benefit, when you do this make sure you dont have the lines up against the washer bottle neck, you may have to pan to the right of the screen to see this clearly
there is a thread on here search 'reflector bumper cover remove' and the guy does a nice write up on how to get the cover off, its actually pretty intuitive, there are two plastic clips at the edges of the lower bumper cover that need a little gentle screwdriver work to pry out undamaged.
take your time and its easy thanks to a great design on subaru's part and a neat kit put together by Perrin made of trusted parts and part or two they seem to fab up in house, like a nifty spacer.
gmookher is offline
Old 09-14-2012, 04:50 PM   #4
gmookher
It can be offset if you prefer!
gmookher is offline
Old 09-14-2012, 04:50 PM   #5
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I need this haha. I wish I knew someone there so I could have tested it as well :P Too many Sebring days in this car's life!
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline
Old 09-14-2012, 05:10 PM   #6
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
When do they go on sale and how much?
ATL BRZ is offline
Old 09-14-2012, 05:12 PM   #7
gmookher
Well, Its a prototype, so i am sure Chris will jump in here any second with news etc. My install was smooth and neat, no holes drilled etc. He did mention there may be a bracket in the works, for the production version. I'm actually fine bracketless, tho I may add a stone shield later
gmookher is offline
Old 09-14-2012, 05:17 PM   #8
ATL BRZ
ATL BRZ's Avatar
I'm pretty sure now after looking at it again that this wont fit with the Airaid intake. Particularly the way the lines and fittings are oriented, the Airaid box occupies that space.
ATL BRZ is offline
Old 09-14-2012, 05:19 PM   #9
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
Thanks for posting the pictures gmookher! We are working on two brackets for the oil cooler that will raise it up a little bit, and make for a little cleaner install. Basically the kit will come with everything needed for a simple bolt on install. If you guys have any questions, let me know!
PERRIN_Chris is offline
Old 09-14-2012, 05:21 PM   #10
ATL BRZ
ATL BRZ's Avatar
Can the fittings and lines be oriented differently depending on the way the adapter threads in? My post above states a potential fitment issue with the intake I'm running.
Pic for reference
ATL BRZ is offline
Old 09-14-2012, 05:25 PM   #11
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
How much?
JoeBoxer is offline
Old 09-14-2012, 05:28 PM   #12
mike2100
mike2100's Avatar
Drives: 23 BRZ
So it's basically the heat exchanger, 2 lines, and sandwich adapter? Not bad
It looks like there's a port in the adapter that allows for an oil temp sensor, is that right?
Does the sandwich adapter get messy when you take the oil filter off?
mike2100 is offline
Old 09-14-2012, 05:38 PM   #13
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
Looks neat! I deffinitely want this if it improves the HP being consistant.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline
Old 09-14-2012, 05:40 PM   #14
PERRIN_Chris
Originally Posted by JoeBoxer View Post
How much?
Pic for reference
We're not sure yet, we will test fit it with intakes in the next few months to see if we can make it work with different intakes. We know for sure it will work with the PERRIN intake that is coming soon.
There isn't a port for oil temp unfortunately. The adapter would have to be taller. But there is a port on the engine already for the factory oil temp sensor, which can be Tee'd off to an aftermarket gauge pretty easily.
It actually doesn't make a mess! We posted some info on this back when we first got the car here: http://blog.perrinperformance.com/2013-brz-exposed/
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
Got my AGP catback installed today!! track_warrior Engine, Exhaust, Transmission 59 08-21-2012 08:10 PM
Greddy oil cooler coming soon DIG1992 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 08-20-2012 12:02 AM
Cooler than drifting! Rampage Other Vehicles & General Automotive Discussions 8 04-03-2012 12:55 AM
