Old 08-30-2012, 07:29 PM   #1
AVOturboworld
AVO Silicone Inlet and Sound Tube DIY
1. Recommended tools on hand - A flathead and philips head screwdriver, and some pliers. Yes, you could probably do it without them if you are on the side of the road and desperate, but it's generally suggested to have at least these.
2. AVO wire-reinforced Silicone Inlet and Sound Tube. Definitely a necessity.
Removal of the standard inlet and sound tube.
3. Removal: Loosen off the big clamp on the OEM hose at the Intake Box end.
4. Loosen off the big clamp on the OEM hose at the throttle body end.
5. Use the pliers to loosen the clamp on the small breather line hose.
6. Then move the clip up and off the inlet to help with removal, and use the flathead screwdriver to carefully pry out the fitting.
7. Loosen off the clamp at end of the sound tube.
8. Carefully pull the sound tubed off.
9. Now carefully pull the entire inlet and sound tube assembly out of the engine.
10. Use the pliers to loosen the big clamp holding the resonator box on the stock inlet, and remove that box. Make sure to remember the orientation of the box (towards the front of the car).
Part 2: Installation
Installation is a simple reverse of the removal process. It's helpful to keep some sort of lubricant on hand, such as plain old dish soap, to help get fittings into the silicone pieces.
1. Fit the resonator box to the AVO Silicone Inlet. Check alignment of the box to make sure it's not rubbing on the pulleys.
2. Fit the AVO Silicone Inlet pipe back in to the throttle body, breather line, and intake box. Keep the clamps loose while you get everything lined up. Then fit the AVO Sound Tube to the inlet pipe. There is a metal pipe insert to fit the two pieces together with.
3. Tighten everything up, and you are ready to go!
Old 08-30-2012, 07:32 PM   #2
F3dzo
F3dzo's Avatar
Drives: 13 fr-s whiteout
Where to buy?
Color options and sound tube delete compatibility option pleaseeee
I'll be back!!
F3dzo is offline   Reply With Quote
The Following User Says Thank You to F3dzo For This Useful Post:
jm1681 (08-30-2012)
Old 08-30-2012, 07:36 PM   #3
thermobox
Drives: 16 Impreza 5dr CWP
Make it available in black and I'm sold.
thermobox is offline   Reply With Quote
Old 08-30-2012, 07:38 PM   #4
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Does it come without the sound tube?
Lee358 is offline   Reply With Quote
Old 08-30-2012, 07:49 PM   #5
jm1681
Drives: MKVI VW GTI
Originally Posted by F3dzo View Post
Where to buy?
Seconded.
jm1681 is offline   Reply With Quote
Old 08-30-2012, 07:52 PM   #6
mashal
DADA
mashal's Avatar
Drives: 2013
Originally Posted by jm1681 View Post
Seconded.
Thirded
mashal is offline   Reply With Quote
The Following User Says Thank You to mashal For This Useful Post:
jm1681 (08-30-2012)
Old 08-30-2012, 07:54 PM   #7
AVOturboworld
All color available (and in stock), and they inlets of course will be available separate from the sound tubes (and vice versa). I'm getting the sound tube caps for the silicone inlets made now.
The Following User Says Thank You to AVOturboworld For This Useful Post:
F3dzo (08-30-2012)
Old 08-30-2012, 08:15 PM   #8
F3dzo
F3dzo's Avatar
Where do i send my money and how much of it??????
jm1681 (08-30-2012)
Old 08-30-2012, 09:28 PM   #9
AVOturboworld
Up on the online shop - just warning, though, they won't ship till next Tuesday because of Labor Day.
http://www.avoturboworld.com/avoshop...-c-95_100.html
Old 08-31-2012, 10:51 AM   #10
Lee358
Lee358's Avatar
What are the gains from doing this other then looks?
Old 08-31-2012, 12:08 PM   #11
AVOturboworld
A little over 10% increase in air flow through the inlet, with a much larger area at the bend vs. stock to smooth flow through. Additionally it gets rid of the accordion section and smooths that out.
Old 08-31-2012, 12:09 PM   #12
jm1681
Drives: MKVI VW GTI
I believe it was 10% greater flow than stock, and the fact that it's a smooth and consistent diameter (76mm) throughout, versus the crinkley oem hose.
Probably not much in the way hp gains doing it on its own, but when coupled with a panel filter (Which someone here proved was good for about 5whp), it'll probably make itself more known
Edit: And I was too late in replying, but hey, at least I had the facts right XD
Old 08-31-2012, 01:23 PM   #13
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 08-31-2012, 10:29 PM   #14
mashal
DADA
mashal's Avatar
Drives: 2013
I know you got decent prices for the packages, but would you be willing to do a Group buy?
Why delete the sound tube? feldy Engine, Exhaust, Transmission 77 04-05-2021 11:12 PM
Sound tube mod? smbrm Engine, Exhaust, Transmission 25 06-20-2012 07:24 PM
Sound induction tube - can it be modded? ahausheer Cosmetic Modification (Interior/Exterior/Lighting) 16 06-05-2012 02:23 AM
The intake sound tube MrVito Scion FR-S / Toyota 86 GT86 General Forum 8 12-09-2011 07:32 PM
Sound induction tube Yay, or ay? ahausheer Scion FR-S / Toyota 86 GT86 General Forum 22 12-04-2011 09:30 PM
