Drives: one
Space under rear seat
Don't have my BRZ yet, but I'm trying to plan ahead. I've looked around and only been able to find a few pics that don't tell me much. I'm wondering how much space is there under the rear seat. Thinking of mounting an amp under there for a cleaner install. Anyone had the rear seat off and can comment on how much clearance there is with the seat back in place.
That Guy
Drives: 2013 asphalt FRS MT
I get the feeling I'm misunderstanding what you're trying to say. There isn't any space under the rear seat cushion, well, I plan on running wires under it, but even that will be tight.
Do you mean under the front seats, or maybe in the spare tire well? |
Drives: one
Sorry, I should clarify. If I were to remove the back seat, is there enough room to install an amp and then re-install the back seat.
Drives: nissan frontier, DGM MT BRZ
I havnt taken the seats out but there might be room where the stock amp is located
Drives: Argento FR-S
I was actually thinking the same thing. I was going to check but the bolts on the seat were super tight. I dont feel like doing the work only to find out that theres no space.
Drives: one
Lee, I'm looking at a 4 channel amp + mono block, or a 6 channel. Not sure if 6 would fit in the stock location and if I went with 4 + mono I'd need somewhere to put the 4.
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
No room. The rear cushions are essentially padding for buckets hammered out of the sheetmetal.
If you get a small enough amp, you could remove the styrofoam at the base of the rear seatback in the trunk and hide it under the trunk floor. If you have to have a large amp, you may have to attach it to the seat back. |
Drives: one
Thanks Draco. I'll probably end up cutting out the foam then.
Im not home im on vacation unless some one does it before i get back ill pull the flooring out of my trunk to show you how much room there is. Its really not much tho
#10 |
First 86 Driver Baby!
Drives: FR-S, Flex
Not to mention the cooling issues you'd have mounting an amp under the rear seat.
#11 | |
Drives: one
That was definitely a potential concern, but it couldn't be too much worse than the stock amp location unless there's some sort of ventilation I haven't seen. |
#12 |
Drives: FR-S, Flex
That's true, which is one of the reasons I'm upgrading my system when I get my car back. I already have a complete system in my garage just waiting to be installed!
#13 |
Drives: waiting on a 2021...
From all the room it looks like there is by the rear speakers, I wonder if you could fab up a mount and stick the amp behind the rear side panel?
#14 |
Drives: Firestorm FRS
Plenty of room behind the rear speakers. Put the amp behind the panel and replace the speaker with a fan.
| Rear Seat Deletes | EvoFanatic | Cosmetic Modification (Interior/Exterior/Lighting) | 110 | 02-23-2015 07:59 PM |
| Sit in the rear seat for me ;) (with photos of people in back seat) | D4ng3r | Scion FR-S / Toyota 86 GT86 General Forum | 125 | 11-14-2013 06:59 AM |
| Rear seat removal? | Shizuma | BRZ First-Gen (2012+) — General Topics | 34 | 04-01-2013 03:36 AM |
| JDM 86 Rear Seat Silencer | ZC6BRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 28 | 12-01-2012 09:33 PM |
| Back seat space | bill323 | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 08-07-2012 03:11 PM |
