Old 06-13-2012, 11:57 AM   #1
Shizuma
Shizuma's Avatar
Drives: 2015 Dodge Challenger SXT
Rear seat removal?
Has anyone taken out their rear seat of their car, specifically the part attached to the floor? If so how did it come out, are there any bolts, does it just pop into place?
I'm trying find out because I have a set of 12" subs that I took out of my Dodge Magnum when I traded it in and I want to put them in my BRZ, however with the trunk being so small and the depth of the trunk being less than the diameter of the subs I don't think the trunk is feasible without losing basically the entire trunk, however since the back seats are virtually useless since there is zero leg room and they seem to dip down pretty low below where the folded back access to the trunk i'm thinking I may be able to build a custom box to put the subs where the back seats are and still be able to open the back into the trunk for when I need to carry large items.
Shizuma is offline   Reply With Quote
Old 06-13-2012, 12:24 PM   #2
Zadkiel
Drives: CBS BRZ Limited 6MT
I'd be concerned that it might mess accidently trigger the rear seat airbag. That or somehow adversely affect normal opperation. I don't know how rear seats and the like are integrated like that in a modern vehicle. Makes me miss my 240. You could strip that thing out without a care in the world. No airbags anywhere.
Zadkiel is offline   Reply With Quote
Old 06-13-2012, 12:25 PM   #3
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
Haven't taken them out but looks like there is one totally exposed bolt per seat bottom and they should just slide out.
sure74 is offline   Reply With Quote
Old 06-13-2012, 12:34 PM   #4
Shizuma
Shizuma's Avatar
Well I wouldn't worry about the rear seat airbags personally because the subwoofers don't need airbags
Yeah, the rain just finally let up so I was able to go out and take a look and saw that one bolt there, if that's it that will make it nice and easy, just gotta check to see if there is enough depth for my subs, which I need just under 8" if I make the boxes out of 3/4" MDF again, maybe 7" if I go fiberglass, so i'm guessing it'll either fit like a glove, or be a hair too tall.
Old 06-13-2012, 01:10 PM   #5
the_3d_man
Drives: 2007 Legacy GT
Just buy a couple of good 10"s and build new speaker boxes. Problem solved. 12"s in this car is ridiculous anyway.
the_3d_man is offline   Reply With Quote
Old 06-13-2012, 01:14 PM   #6
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
The trunk is actually quite deep. There's a large foam tray under the "floor" containing the spare tire and a bunch of jack tools. But a LOT of foam. I haven't researched it, but I'd think you could remove the spare and foam tray and tools and dynamat the metal floor, giving you a lot of space for subs and an amp. Just an idea.
I don't run a spare tire in my other car, and if you pull the spare, no need for the jack and tools either.
ashtray is offline   Reply With Quote
Old 06-13-2012, 01:26 PM   #7
Shizuma
Shizuma's Avatar
Blasphemy! No car is too Small for a pair of 12" subs :p
Either way though I already have $1300 worth of speakers + amp from my Magnum, so it makes no sense to buy new stuff if I can make my current setup work in the BRZ.
I thought about removing the spare to possibly put the subs there, but i'd really like to have it available just in case. And there would have to be a whole lot of foam to put a 12" in without eating up a lot of the trunk/taking out the spare, even the 10" sub box I've seen for the BRZ they had to angle the sub quite a bit to fit in in the shallow trunk height. And since the back seats are 100% useless why not make use of that spot, as much as Subaru wants to call the BRZ a 2+2 it's really just a 2 seater with a storage area behind the front seats, I honestly wonder if they did it strictly for insurance reasons or vehicle classification or something because there's no value added with those "rear seats".
Old 06-13-2012, 02:06 PM   #8
Sushi Boy
Drives: Japanese
false floor would be sick making it look like you just have your rear seats folded..
Sushi Boy is offline   Reply With Quote
Old 06-13-2012, 03:11 PM   #9
Shizuma
Shizuma's Avatar
This is a real rough image of what i'm thinking of doing, so the top of the box would have a layer for acoustically transparent fabric so the subs wouldn't be visible and the top of the box would be flush with the center hump so the back seat could still fold flat when needed, also I would put speaker grills over the speakers but under the fabric so I can put stuff back there without worrying about damaging the subs.
Old 06-14-2012, 09:18 AM   #10
sure74
sure74's Avatar
My 2yo rides back there quite comfortably. I wouldn't have bought the car otherwise.
Old 06-14-2012, 09:24 AM   #11
Shizuma
Shizuma's Avatar
True, a childs seat does fit back there, but I bet 99% of the people buying a brz/fr-s don't have carying a baby/young child around in a car seat in their mind as it's not a family friendly car.
Old 06-14-2012, 09:46 AM   #12
aethelwulf
Drives: 05 Sti 20g'd
That's kind of what a 2+2 is... S14, 944, etc. all have pretty similar back seat situations to the BRZ and there have been plenty of people that have shown it's possible to get people back there in a pinch. Sure, it's not the best place to be, but it can be done.
aethelwulf is offline   Reply With Quote
Old 06-14-2012, 10:02 AM   #13
Shizuma
Shizuma's Avatar
It seems virtually imposible to me, as i'm 5'-8" which while tall for a woman really isn't that tall in general, I would bet almost all the guys driving the car are my height or taller than me, with the seat adjusted for me there is only 1" between the front seat and back seat, too small for anyones legs to fit back there, now I could possibly see if you squish the person in the passanger's seat you could squeeze someone in the back on that side, but the drivers side? I don't see it as possible unless the driver is a really short woman around 5'-0"
Old 06-14-2012, 10:24 AM   #14
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I got a friend that was about 220 pounds and 6 foot with another 6 foot guy around 130 pounds behind him.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Sit in the rear seat for me ;) (with photos of people in back seat) D4ng3r Scion FR-S / Toyota 86 GT86 General Forum 125 11-14-2013 06:59 AM
Rear seat question, version 2.0 8987846 BRZ First-Gen (2012+) — General Topics 29 06-05-2012 06:13 PM
would rear-facing baby seat fit? ranisron BRZ First-Gen (2012+) — General Topics 17 02-27-2012 11:49 PM
Crazy idea... the Rear Seat info ? MRZ415 Scion FR-S / Toyota 86 GT86 General Forum 78 01-27-2012 12:19 PM
Pics of people sitting in rear seat glorydays FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 12-08-2011 04:54 AM
