Old 05-20-2026, 12:10 PM   #1
TStafford
TStafford's Avatar
Drives: 2015 FR-S Ultramarine Metallic
PCV and oil cap question
I had the smell of oil dripping onto the exhaust after driving my car. After not finding any leaks or oil on the exhaust, I thought maybe it was the PCV. I replaced the PCV, but as part of the testing process, I removed the oil fill cap and noticed that air was puffing out of the opening when the engine was idling. Is that normal? This happened before and after the PCV replacement. The hose is not blocked.
TStafford is offline   Reply With Quote
Old 05-20-2026, 02:05 PM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Any time a fluid (gasses and liquids) has multiple ways to escape a high pressure location it will take an "all of the above" route. I haven't observed this specifically, but it makes sense that you would notice this happening.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
Old 05-20-2026, 04:15 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Just to add onto this, is your car a manual? May be the rear cam plate. Passenger side rear of the engine, run a rag under there and I bet you'll find the source.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
DarkPira7e is online now   Reply With Quote
Old 05-21-2026, 09:39 AM   #4
TStafford
TStafford's Avatar
The car is a manual. I will check the location you suggested for oil leakage.
The smell of oil seems to be gone.
The question is this: Is it normal (with a good or new PCV) for air to puff out of the oil fill tube when the engine is idling? This is tested with the cap removed.
Old 05-22-2026, 03:05 PM   #5
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
Yes, it is normal.
Engine produce pressure, no engine is designed to be run with the oil cap off.
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 05-24-2026, 11:32 AM   #6
TStafford
TStafford's Avatar
The funny thing is, I got the idea from a YouTube video on how to check your PCV status.
I did what I think is the correct check, which was to shake the valve and see if it was stuck. Also, did it rattle like the new PCV?
The old one would rattle, but it was sluggish. Given the price of the new one and since I had to remove the old one to check it, I planned to swap it either way.
The car has about 50,000 miles on it.
SU003-06103 = $11.40
Old 05-24-2026, 10:04 PM   #7
ZC6_STi
ZC6_STi's Avatar
Drives: 2015 Subaru BRZ Series.Blue #709
Yep, its suppose to rattle brand new. Sluggish rattle is a symptom that it is about to fail. If it doesn't rattle, then the internal value isn't operating correctly. PCV is required to be replaced every 30,000 miles to fix the rough idle, and if there is a distinct oil smell. I replaced it with the WRX/STi PCV since it holds better pressure compared to the BRZ/GT86/FRS version.
ZC6_STi is offline   Reply With Quote
Rubber cap next to PCV valve? FRS10Series Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 11-15-2023 08:54 AM
SARD CF Intake Pipe, SARD Oil Catch Can, TRD Oil Cap, Rad Cap, Battery Clamp Trojan_SC Engine, Exhaust, Bolt-Ons 19 03-28-2018 07:52 PM
Mishimoto PCV catch can and PCV valve nearvincent Forced Induction 7 08-01-2017 04:58 PM
TRD oil cap, radiator cap, gas cap, shift knob GodSays Exterior Parts (Aero, Lighting, Etc.) 3 06-08-2015 05:39 PM
86 oil cap > grimspeed oil cap! Sexyeve Cosmetic Modification (Interior/Exterior/Lighting) 24 09-10-2013 12:54 AM
