Old 07-28-2017, 10:24 AM   #1
nearvincent
Drives: GT86
Mishimoto PCV catch can and PCV valve
Hi all
My car will be boosted very soon and I'm planning on installing the Mishimoto PCV catch can. Would I need to change the PCV Valve? If so which PCV valve should I go? And would I need to get a check valve too?
Thanks!
nearvincent is offline   Reply With Quote
Old 07-28-2017, 10:26 AM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
It's a complete kit it should include a check valve already.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 07-30-2017, 01:41 AM   #3
nearvincent
Drives: GT86
so the mishimoto kit already has a check valve?
Old 07-30-2017, 05:49 PM   #4
mrg666
pessimistic skeptic
mrg666's Avatar
I can't see any PCV valve included at the product page. However, there is already a PCV valve on the engine block. You can add a 12mm check valve on the intake manifold side (blocking the blow out from intake manifold). The second check valve is recommended for FI.
Old 07-31-2017, 06:49 AM   #5
nearvincent
Drives: GT86
So i can just use that boomba 12mm check valve without needing to replace the stock PCV valve on the block? I will be boosted very soon.
Thanks for the help!
Old 07-31-2017, 03:14 PM   #6
mrg666
pessimistic skeptic
mrg666's Avatar
When you have the oil catch can, the check valve on the intake manifold side is better than replacing the PCV valve. Boosted air can potentially leak from (or at least expand into) the catch can. Check valve will stop the air flow before going into the catch can.
Old 08-01-2017, 07:17 AM   #7
nearvincent
Drives: GT86
Okay, all makes sense now. Should i bother upgrading the PCV valve too or is that overkill?
Old 08-01-2017, 04:58 PM   #8
mrg666
pessimistic skeptic
mrg666's Avatar
It is not necessary to change the PCV valve anymore with the check valve added. I would make sure the check valve is working before installing. Blow from both sides, it should not leak air in the opposite side to the arrow marked on the check valve.
Mishimoto Catch Can $100 shipped The Tengu Engine, Exhaust, Bolt-Ons 0 07-17-2017 01:38 PM
WTB:Mishimoto Catch Can wrb.brz Want-To-Buy Requests 1 03-04-2017 01:02 AM
Mishimoto oil catch can Bigbell224 Engine, Exhaust, Bolt-Ons 4 05-01-2016 09:11 PM
FS: Mishimoto Baffled Oil Catch Can zeal86 Engine, Exhaust, Bolt-Ons 7 04-29-2015 08:44 AM
Win a Mishimoto Oil Catch Can! Mishimoto Announcements, Contests, Giveaways 68 10-23-2013 05:27 PM
