Old 03-29-2026, 05:23 AM   #1
DC2R
Drives: 2014 Scion FR-S
Lost key fob - What are my options?
I've managed to lose both my key fobs for my 2014 FR-S. I am currently using the valet key. The dealer wants $200 for a key fob and $200 to program it. Are there any cheaper solutions?
I am also interested in getting a remote start system at some point. Could I just use the lock/unlock and trunk pop functions from an aftermarket remote?
DC2R is offline   Reply With Quote
Old 03-29-2026, 09:09 PM   #2
Luns
Drives: 2017 GT86
There are mobile locksmiths who will do all of this for much less than the dealer, but the hard part may be getting an appropriate blank key for them to use - our cars have a unique transponder not shared by other Toyotas even though the key outwardly looks identical to other cars. They can try using the blanks they have and it's on them if it doesn't work but OTOH if it does work, you're also paying them to take that chance.
What I've done has been to buy two used keys off of eBay, and removed the transponder and remote control from them to put in new key shells. Given you still have your valet key, the new keys can be programmed by anybody with an appropriate scan tool, and any decent locksmith can cut the key blade for you. (*)
Note that decent locksmiths may be hard to find. I know that locally, some old formerly reputable businesses have been sold to new owners who don't know what they're doing. You don't want them to do a straight copy of the valet key - you will end up with another valet key which won't open the trunk physically, though maybe you don't mind that. Ideally you'd find someone who knows how to read your existing key blank (Toyota cuts are easily read by eye) and can cut a new key from code.
Luns is offline   Reply With Quote
Old 03-30-2026, 09:35 AM   #3
smackrel
Full Throttle!
Drives: 17 CBSP Limited PP
Do you happen to know what type or brand of scanner will program a key fob?
Asking for a friend that has a spare that came from eBay that needs programming and local locksmiths refuse to even try it.
smackrel is offline   Reply With Quote
Old 03-30-2026, 10:17 PM   #4
Luns
Drives: 2017 GT86
Toyota Techstream is what the dealerships use for the programming. Any scantool that replicates its feature set would do.
I haven't used the Toyota edition of the Launch Creader Elite, but have played with the 2024 Honda version, and it included immobilizer programming options found in Honda HDS. I would expect the Toyota version to replicate Techstream's feature set as completely as the Honda version does HDS, so I fully expect the Creader Elite would work.
There are likely many other scan tools - perhaps even others within the Launch product line - which would work, but I don't have experience with them.
There are also bootleg versions of Techstream itself that are often sold together with the requisite cable. I don't know if I trust these to be free of malware, or if the media distributed might still require a license key that's not included. OTOH, they're readily available, not too expensive, and I haven't heard of anybody actually getting into any trouble, so they could very well work too. If you want to try your luck with that, you can search eBay for a Mini-VCI cable.
Old 03-31-2026, 06:09 PM   #5
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
The fobs are cheap from a number of places. The vehicle's computer is programmed to "memorize" up to 5 different chips. Also a good idea to clear the original two (2) that originally came with the vehicle - sounds like you only had one - plus the valet key.
The 2014 FR-S uses a Subaru G-chip (or similar Subaru system) - same as the BRZ. You can even get a facsimile "flip" fob without the Subaru logo on eBay as possible upgrade.
The valet key does not have all of the cuts of the ignition key, so you will need the key code to cut new ignition key(s).
tarzan_nojane is offline   Reply With Quote
Old 03-31-2026, 06:28 PM   #6
Luns
Drives: 2017 GT86
Originally Posted by tarzan_nojane View Post
The fobs are cheap from a number of places. The vehicle's computer is programmed to "memorize" up to 5 different fobs. Also a good idea to clear the original two (2) that originally came with the vehicle - sounds like yo only had one.
The code is easily read from the key.
The valet key differs from the master key in only one cut right at the tip which is not even a part of the normally recorded key bittings. The valet key blank comes with the tip precut to reflect valet usage. Vehicle-specific cuts are made identically onto valet and master key blanks.
Old 04-19-2026, 10:39 PM   #7
DC2R
Thanks for all the info!
I tried to copy the valet key but it wouldn't start the car due to not containing the immobilizer. What are the extra cuts in the key fob key? I'm guessing it adds the ability to open the trunk with the key.
So the way I take it I need to buy a new BRZ key fob and have it programmed to the car via techstream or similar app using a special cable. I am tuned using OpenFlash Tablet (soon to switch to ECUTek), does that complicate things? I've seen Toyota key fobs on Amazon. Would the one below work?
https://www.amazon.com/gp/product/B0...LFXZIQJ2T&th=1
Old 04-21-2026, 12:40 PM   #8
tarzan_nojane
Drives: 2014 FR-S
The car's ECU gets programmed, not the key. Up to five key chip signatures can be stored, so part of the process is to "forget" the lost/missing units.
Search for the term "FR-S" in the 184 reviews for the Amazon unit linked to above...
Old 04-22-2026, 08:08 PM   #9
Luns
Drives: 2017 GT86
The only difference between valet and regular (master) key are that the valet blank has a little material that's been pre-cut at the tip of the key. That prevents it from opening the trunk. All the cuts that distinguish keys for one car from another are after that valet cut, and the locks for the rest of the car ignore the tip where valet and master blanks are different.
I'm not familiar with how OFT and ECUTek interact with the immobilizer system, so cannot say if it will complicate things. But otherwise yes, the car will need to be programmed (with Techstream or equivalent) to recognize whatever new key you acquire. That programming does not depend on actually turning the ignition, so you can actually do the programming before you have the key blade cut. That way, if the programming fails (because the key doesn't have the right immobilizer for your car) you could still return the uncut key for a refund.
That Amazon key will not have an appropriate immobilizer, though the keyless entry remote will probably work. It will work though as a recipient for a transponder you harvest from another key. As I mentioned before, the FR-S/BRZ/86 use a transponder that is unique to them and not shared with other cars. If a listing has any mention of any other car at all, then its transponder is not for you. If a listing has an SU003 part number in its description, it's a good sign.
Warning - pedantic content ahead.
Your use of the word "Fob" although now common, irks me as someone old enough to know where the word comes from. Not trying to call you out personally - not your fault - just part of a bigger shift of word usage.
A fob chain was a chain attached to a pocket watch that allowed you to pull the watch out of your pocket to check the time. Usage of the word got extended to things attached to a key chain which you could also grab in lieu of your key, and use to pull your key from your pocket.
When the first remote entry controls for cars came out, they were separate from the key, attached to a shared key ring. Being attached to the key, it was legitimately a fob - a fob remote - that you could grab and pull on to retrieve your keys without having to touch the keys directly. The word fob is not a synonym for remote control, it describes the fact that the remote control was attached to - but separate from - the key.
For keys that the remote is integrated into, the remote not being a separate item from the key means that it is not a fob.
Old 04-23-2026, 01:09 PM   #10
smackrel
Full Throttle!
Interesting, if the current slang term for it is incorrect, that makes me wonder what the correct term for it would be?
Old 04-24-2026, 09:14 PM   #11
Luns
Drives: 2017 GT86
Sadly, I don't think there's a single canonical term that rolls off the tongue nicely. But in practice, just referring to the car's "master key" is unambiguous enough.
Toyota called keys without the valet cut "Master keys" regardless of whether there was an integrated remote or not. For US market FR-S and 86 anyway, the master keys never came without the remote, so unlike say the Corolla, we don't have a need to distinguish between a plain master key and a master key with the remote.
Honda called them "key with remote transmitter". I haven't looked into what other makes call things.
Some call it a keyless entry key, which sounds like an oxymoron to me, but I'm okay with it.
Old 05-11-2026, 06:33 PM   #12
DC2R
Ah, so it seems the Amazon key I linked does not work for 2014 FR-S. As all I have is a valet key I guess any key I have cut will not work for the the trunk. Is my best bet just trying to find a used brz/FR-S key on eBay plus this key and then swapping the guts, programming it to car, and then having it cut from the valet key?
Old 05-13-2026, 04:12 PM   #13
Luns
Drives: 2017 GT86
Pretty much.
The remote will swap over straight, but the remote from the Amazon key may work just as well.
The transponder is held in the key with hot-melt glue. The best way I've found to remove it is to just take the key shell and soak it in hot water (McDonald's coffee lawsuit hot). It pries out easily then, and the transponder itself is quite waterproof.
A good locksmith with an HPC Blitz machine or equivalent can cut you a factory fresh master key given your valet key, but expect to pay for the privilege. There are also people on eBay who will sell you a cut-by-photo key; you can see if they're willing to skip the valet cut in the process.
A knowledgeable locksmith without the Blitz machine can do it too, either with space and depth keys, or by just duplicating your valet key skipping the valet key as they do it. Manually skipping the valet cut is a slight gamble, but they can do a test key on a plain metal (no transponder) blank.
Old 05-14-2026, 10:59 AM   #14
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Your best bet is to go to the dealer, pay the stupid tax for losing both keys, and have it done right.
DIY: Lost Key Fob Remote Replacement for FR-S customfab87 DIY (Do-It-Yourself) Guides 8 06-14-2020 12:07 AM
Key fob wasn't unlocking door/trunk until I used my physical key. btan219 Electronics | Audio | NAV | Infotainment 2 07-18-2017 06:26 PM
Lost key fob GT86 Dan66 Scion FR-S / Toyota 86 GT86 General Forum 13 08-21-2015 01:01 PM
WTB GT86 Key Fob,Smart Key bape47 Want-To-Buy Requests 2 04-17-2014 03:39 AM
Lost my key... Found my key theredtape BRZ First-Gen (2012+) — General Topics 23 11-22-2012 05:59 PM
