hey you, yeah you <3
Drives: 2014 37J FR-S
Negative Battery Terminal Part Number?
Does anyone know part number for the negative battery terminal with clip portion?
Mine is in dire need of replacement. Local Toyota asked me to bring it in to 'confirm' part, but refuses to share part number over phone. ![]() Positive Battery terminal: SU00302356 Fuse-link attached: SU00302430 Negative Battery terminal: SU003-00510 ????? it's missing clip portion and fuse or unsure of what circled part is. Used Forum search function. Cannot find part number. =( ![]() Subaru came through! 23775AA060 thats part.
Drives: Subaru BRZ
Wonder if the following has it?
USA, 86 264420, ZN6EY-C7, 82-01 BATTERY & BATTERY CABLE - Catcar.info https://share.google/85pN8ChmxKdJq0Cq0 |
Thanks. Name of piece is Battery Current Sensor. Cant find in on Subaru or Toyota parts.
Drives: 2016 Scion FRS Release Series 2#439
Perhaps the cable, sensor and terminal clamp are one part number???
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) |
The Toyota Canada parts website for my 2016 FRS shows;
Negative Term SU003-00510 $52.69 Fusible Link SU003-02430 $9.69 Hopefully this helps.
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) Last edited by Muskoka800; 12-28-2025 at 10:30 AM. Reason: Added detail |
Drives: Subaru BRZ
| Part number for fusible link block on positive battery terminal? | Jack Black | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 08-24-2022 08:58 AM |
| Plug connected to negative terminal on battery. | crazyfrenchbiker | Electronics | Audio | NAV | Infotainment | 9 | 07-21-2021 03:29 PM |
| Stupid negative battery terminal bolt | Legoshi | Engine, Exhaust, Transmission | 2 | 06-17-2021 11:32 PM |
| Negative Battery Terminal | UNCC_BRZ | Electronics | Audio | NAV | Infotainment | 2 | 09-19-2018 10:23 PM |
| Negative battery terminal disconnect effective? | ZionsWrath | BRZ First-Gen (2012+) — General Topics | 11 | 07-21-2018 04:38 AM |
