Old 01-18-2016, 10:47 AM   #1
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
Plug connected to negative terminal on battery.
Is anyone familiar with what these 4 wires are for?
I've tried just grounding them to the chassis and the car won't start anymore, they need to be connected directly to the battery.
I'm trying to relocate my battery.
crazyfrenchbiker is offline   Reply With Quote
Old 01-18-2016, 10:53 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
PICS??
Old 01-18-2016, 11:00 AM   #3
crazyfrenchbiker
Hot Lava 6MT
Old 01-18-2016, 11:12 AM   #4
NahumCC
Drives: 2013 FR-S 10 Series
Looking through the shop manual it appears to be a sensor for determining battery temperature. Starts on page 3057 of the shop manual.
NahumCC is offline   Reply With Quote
Old 01-18-2016, 11:15 AM   #5
Chimera
Drives: FRS
So truthfully I have never relocated a battery, however I always assumed one would simply hook thick copper lines to the terminals, run them to the new location, and attach new terminals to the end. Would that not work?
Old 01-19-2016, 06:04 AM   #6
crazyfrenchbiker
Hot Lava 6MT
Yes, that can be done and that's how most kits work, I'm simply hoping to shave weight and remove the terminals. I wonder if it's possible to disable the sensor.
Old 01-19-2016, 09:49 AM   #7
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
It is the battery current sensor. There's more to the circuit than all of the wires being connected the ground so that will not work. I'm not fully sure how it works but there's likely a positive in that bunch of wires too, so if you ground that line that's likely to stop the electronics from working that are on the other side. That may be causing your not starting issue. The circuit's built into the negative terminal connector so you might be forced to leave it. The current is needed so the ECU can make sure the alternator keeps up with the power consumption and doesn't drain the battery while driving.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
The Following 2 Users Say Thank You to zkv476 For This Useful Post:
jcw99 (07-23-2021), Strife26 (01-27-2018)
Old 08-02-2018, 03:31 PM   #8
94CelicaGT
94CelicaGT's Avatar
Drives: '14 Firestorm FR-S M/T
So this happened..
Sorry for resurrecting an old thread but i did a search and this is what came up.
I had a clunking sound in the car for a while and when i decided to check it out it was that my battery tie down rattled loose. The short j-bolt was completely gone and the battery was clunking around inside the engine bay and the wires on the battery current sensor were all severed but one, the green one which is VIN most likely the power for the sensor.
I can confirm the car works without this connected. Doesn't even throw a cel. Not sure how long it will be before the battery goes dead or explodes or whatever. maybe nothing?
Does anyone know how long the car will run like this? Is it even charging the battery like this? overcharging it?
94CelicaGT is offline   Reply With Quote
Old 07-21-2021, 03:11 PM   #9
Jacluley
Drives: 2013 FR-S, White
Second Revival
Sames as above, sorry this looks ancient, but I thought I would add in what I found. I had exactly the same issue as last post, and think I have found the correct connector to replace it. I will update if it ends up not working.
https://nexelec.com/YAZAKI-7283885330/
Just attaching the info, not recommending that as a source. It appears to be a connector common on Nissans, so pigtails are available.
Jacluley is offline   Reply With Quote
The Following 3 Users Say Thank You to Jacluley For This Useful Post:
jcw99 (07-23-2021), soundman98 (07-21-2021), Ultramaroon (07-21-2021)
Old 07-21-2021, 03:29 PM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
Welcome! Thanks for the info.
Part number for fusible link block on positive battery terminal? Jack Black Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 08-24-2022 08:58 AM
Lost my battery terminal nut. qqzj BRZ First-Gen (2012+) — General Topics 3 08-05-2014 07:51 AM
Battery Terminal Fuse replaceable? STS-V Scion FR-S / Toyota 86 GT86 General Forum 1 03-14-2014 08:36 PM
Battery Terminal Fuse replaceable? STS-V Electronics | Audio | NAV | Infotainment 0 03-14-2014 08:23 PM
Battery Terminal for Amp Install rbizzle004 Electronics | Audio | NAV | Infotainment 3 06-05-2013 12:46 AM
