Old 06-17-2021, 07:30 PM   #1
Legoshi
Legoshi's Avatar
Drives: 2015 Firestorm FR-S MT
Stupid negative battery terminal bolt
Hi guys,
I'm installing the radium oil catch can in my twin and I am stuck on step one. I need to remove the main negative lead on the battery and adjust it 90 degrees so that the catch can can sit in it's place. It's stuck and I've been trying to remove it for two hours. I've tried pb blaster, breaker bars, and impact wrenches and NOTHING has worked. How the hell do I remove this bolt?
I have dropped the transmission, torqued bolts with multiple universal joints, and nearly broken my arms undoing bolts on this car, but THIS goddamn bolt is THE most difficult and time consuming bolt I have ever had the displeasure of unfastening.
Help a homie out please
Legoshi is offline   Reply With Quote
Old 06-17-2021, 09:18 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
i would take it off the battery first, and then hold it with a channel locks while using an impact to break it loose.
Old 06-17-2021, 11:32 PM   #3
Legoshi
Legoshi's Avatar
Exactly what I did! Worked first try. Thanks for the tip!
Plug connected to negative terminal on battery. crazyfrenchbiker Electronics | Audio | NAV | Infotainment 9 07-21-2021 03:29 PM
Negative Battery Terminal UNCC_BRZ Electronics | Audio | NAV | Infotainment 2 09-19-2018 10:23 PM
Negative battery terminal disconnect effective? ZionsWrath BRZ First-Gen (2012+) — General Topics 11 07-21-2018 04:38 AM
Battery Brace touched Positive Battery terminal, car won't start!! 7m28 Issues | Warranty | Recalls / TSB 21 09-24-2017 12:55 PM
Battery Terminal for Amp Install rbizzle004 Electronics | Audio | NAV | Infotainment 3 06-05-2013 12:46 AM
