Drives: 2013 frs base
Minor oil leak
A couple of weeks ago, I noticed a faint hot oil smell. Upon inspection, there was oil on the skid plate. The FA24 has been in the car for almost a year.
Fortunately, it turned out to be an easy fix. Some one must have been in a bit of a hurry when they installed the dipstick tube. I still had the tube from my old engine with an intact "O" ring that I transferred to the FA24 tube. Moral of the story: When you are putting your tube in the hole, use some lube and work it in slowly. Gentle oscillations and kind words can help. After all, they don't call it an "O" for nothing. |
Drives: 2013 FRS
I had the exact same problem. Showed up at my first race tho. The oring was split so an easy paddock fix. Likely damaged when I inserted the tube.
Sent from my SM-S901U using Tapatalk
WIFE: "How can there be anything left to buy?"
Is the O-ring for where the tube goes into the block?
Drives: 2013 FRS
Yes. And its not a normal round o-ring. It has a bit of a crown to its outer edge. I'd suggest using the OE part instead of something out of an assortment kit.
| Best place for towel to check if I have a motor oil leak? Also question about low oil | btan219 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 16 | 03-14-2019 10:09 AM |
| Deformed VVT-I Oil Control Valve Caused Oil Leak | N1rve | Issues | Warranty | Recalls / TSB | 9 | 05-06-2016 12:10 AM |
| Oil leak after my first oil change.. WTF? | jgonx213 | Issues | Warranty | Recalls / TSB | 16 | 04-17-2014 04:08 PM |
| 2011 Subaru STI Minor Paint correction | OTD | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 18 | 06-05-2012 03:36 PM |
| BMW Z4M Minor paint correction/ Photo shoot | OTD | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 4 | 05-27-2012 12:15 AM |
