Drives: DGM 15' BRZ Limited
Best place for towel to check if I have a motor oil leak? Also question about low oil
Wondering where the best spot under a car to put a towel would be to check if I have an oil leak. Would it be right under the oil drain area? Gonna leave towels over night or a day to check.
I did my oil change on june 2018 with about 5.5 qt. Since then I've driven about 4.4k miles. I drove 25min yesterday so the engine was hot, parked and turned off car on a flat surface. Cleaned the dipstick, stuck it back in and one side was well above the top dot and the other side was well below the lower dot. Did this twice. I know the brz dip sticks are finicky, but from what I've read online is to always go by which side is lowest, and going by that it would mean i pretty much have no oil left. This is difficult to believe since I do not drive hard, rarely pass 4k rpm. I can probably count all the times I've gone red line since my last oil change with two hands. Would it be weird for it to be drained that much with less than 5k miles unless I had a leak? |
Wheels for Brains
Manual calls for 5.7 quarts when doing oil with new filter. Manual says to check oil after waiting 5 minutes.
Try sanding the oil dipstick lightly between the two fill marks. It will help with oil adhesion. You read the oil where there is a distinct level (not necessarily where you see any sign of oil, since it can splatter and be up the dip stick holder), usually it looks like a slight diagonal on the stick: o----\|||||o The amount of oil from the low to full mark is 1L (or 1.1 qt) Also, the manual states that maximum oil consumption before you should go to the dealer is 1.1qt/600 mi Last edited by EndlessAzure; 02-12-2019 at 06:52 PM. |
| The Following User Says Thank You to EndlessAzure For This Useful Post: | ermax (02-13-2019) |
If your engine does have an oil leak, it most likely be from the timing chain cover or the crankcase drain plug.
However, I suspect you are just reading the dip stick funny. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Mr.ac (02-13-2019) |
Did you wait more than five minutes after shutting off the car to check?
[insert cool phrase here]
Drives: BRZ Premium
Sounds like your car is totaled.
If you keep it longer it's going to explode a piston. Unfortunately when they do come flying out it's going through the drivers side and hit you square in the nuts. Lucky for you I'll be willing to buy that death trap. How does $500 sound? I'll even pick it up.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following 2 Users Say Thank You to Mr.ac For This Useful Post: | gravitylover (02-13-2019), soundman98 (02-14-2019) |
#6 | |
Also as others have pointed out you need to wait 5mins and note that the top dot is full and the bottom dot is 1qt low. If it's dry on one side then it's sort of a mystery what is left in there. Wait the 5 mins and check it, then add a little oil and recheck to see how much it comes up and repeat. My guess is you just aren't getting a good reading. |
| The Following User Says Thank You to ermax For This Useful Post: | Tcoat (02-13-2019) |
#7 | |
As Er says they are messy but don't usually mean a large or rapid loss.
Drives: FRS 2013
I found no point in checking the oil even after 5 minutes, there is too much oil in the dip stick tube that will make reading the dipstick hard. Check first thing in the morning before startup for an easier reading.
A rigid piece of cardboard works best for checking oil. Just put it underneath the engine. |
#10 |
Drives: Black frs
Put a new oil drain plug crush washer on each time you change out the oil.
#11 | |
Drives: BRZ Premium
| The Following User Says Thank You to Mr.ac For This Useful Post: | humfrz (02-15-2019) |
#12 | |
#13 | |
Drives: FRS 2013
Not for me. I drain exactly 5.4L (~100mL less due to spillage) as the manual states every time I do an oil change. When I check the oil in the morning it is right at the max dot. Engine doesn't burn or leak anything, never top off oil even with a 10k oil change interval. |
| The Following User Says Thank You to highway7 For This Useful Post: | Tcoat (02-15-2019) |
#14 | |
Just brought up the proper way so that the ones that don't know are not fooled into thinking they are fine with the level halfway between the dots when the engine is cold. Checking cold is fine when you know that it is full but could be a disaster if it isn't but you think it is.
| *SONIC MOTOR - Your #1 PLACE for all things wheels! VarrsToen|WEDS|SSR|VOLK| & more!* | Sonic Motor | Wheels and Tires | 37 | 05-03-2016 02:48 PM |
| Choosing a Great Towel for Drying Your Car | Junkman2008 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 8 | 02-10-2016 04:22 PM |
| Paper towel car scratches Raven FRS | PStaff716 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 15 | 10-23-2013 05:13 AM |
| Now THAT'S a towel! | KSC | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 12 | 05-06-2013 06:02 PM |
| Trans/Motor Mount question | DanoFA20 | Engine, Exhaust, Transmission | 5 | 03-02-2013 03:16 PM |
