Drives: Hot Lava FR-S
P0300 P0301 p0171 P119F P219A p1170
IM still running into issues. Same Idle misfires and the occasional stutter when i gas from a dead stop. absolutely no misfires under boost or heavier throttle. Misfire travels throughout cylinders. Some days its 1 or 2 or 3 or 4. I've cleaned injectors (both), done compression test, plugs coils everything.
Please take a look at my datazap. Car still runs fine except the misfires. ITs crazy that this has been a years worth of misfires and the car still runs but im hitting a wall om rectifying this issue. Its getting more and more complicated for me to pass inspection as well here in NY. ANY help would be greatly appreciated https://datazap.me/u/kxngcorey P0300 P0301 p0171 P119F P219A p1170 <<----NEW CODE. NEVER SEEN THIS IN MY LIFE LOL
2015 Hot Lava FR-S IAG 800 FBM Turbo Kit
I forgot this is a IAG 800 w/ built heads and stock Cams.
Drives: 2020 toyota 86
Have you tried a new battery?
Drives: 2013 frs base
How much Googling have you done? This pops up pretty quick:
https://www.ft86club.com/forums/showthread.php?t=148424 |
#5 | |
Too much tbh. So far ive done Vacuum leak check, compression test, changed all the gaskets, cleaned the the direct injectors, cleaned the port injectors, changed spark plugs, got new coil packs, changed cam sensors. im stuck
#6 | |
Did you new gaskets include exhaust? Was you vacuum leak test with smoke? |
Yes with smoke. and new exhaust gaskets. i know some people see the misfires but dont feel/hear them but i do with mine on occasion.
#8 | |
https://www.ft86club.com/forums/showthread.php?t=99994 |
| P0301, P219A, P119F, P119E | BrZ_Good | Issues | Warranty | Recalls / TSB | 10 | 04-16-2025 10:33 AM |
| CEL P0171, P1170, & P219A | Feargt86 | Software Tuning | 3 | 03-02-2021 02:53 PM |
| P219A, P119F - Air Fuel Ratio Imbalance | hui202 | Issues | Warranty | Recalls / TSB | 14 | 08-16-2019 06:47 PM |
| P0302, p219a, p0352, p119f, used car woes. | Dara321aaa | Issues | Warranty | Recalls / TSB | 8 | 04-29-2019 09:44 PM |
| Click/clanking sound w/ P219A, P119F, P0302 | Kentoxik | Issues | Warranty | Recalls / TSB | 7 | 01-24-2019 09:23 PM |
