Old 03-02-2021, 12:46 PM   #1
Feargt86
F3AR86
Feargt86's Avatar
Drives: 2016 Scion FRS
CEL P0171, P1170, & P219A
According to these codes, the possible causes are intake leaks, bad sensor, bad injectors, and air/fuel imbalance. I had my car tuned last year in april with the following mods: cat-back exhaust, front pipe *catless*, uel header, overpipe. It ran great and last month i installed a inlet hose to replace the soundtube from perrin, a new drop in filter from grimmspeed and no CEL's until last week I decided to do some donuts, following day all these codes came about. I did replace a broken gasket on the header manifold that was broken but that didn't fix the issue, nor did cleaning the MAF did nothing either. So now I'm stumped, any ideas fellas? I have a 2019 gt86 trd
Feargt86 is offline   Reply With Quote
Old 03-02-2021, 01:01 PM   #2
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
I would double/triple check that there are no leaks in your intake and exhaust again first. I can't think that the sound tube and filter would tweak your A/F enough to pop these codes up. If you're on EcuTek, I'd do a log and check with the tuner again.
Dzmitry is offline   Reply With Quote
Old 03-02-2021, 01:07 PM   #3
Feargt86
F3AR86
Feargt86's Avatar
Yeah, my tuner said if there is any new air mods to the car, it will affect fueling. I am going to see him today to figure out whats up, because the car is in slip mode as well.
Old 03-02-2021, 02:53 PM   #4
tomm.brz
Drives: brz 2017 hksv2
post a log if you want some help though
Weird AFR and fuel trims P1170 P0171 Tonypepatone Issues | Warranty | Recalls / TSB 19 06-18-2019 08:20 PM
Check engine codes P0171, P1170, C1201, C1231, and c1241 HELP Crystalwhitebrzsti Issues | Warranty | Recalls / TSB 10 05-30-2019 06:45 AM
Odd idle and P0171 and P1170 codes dave- Engine, Exhaust, Transmission 0 09-26-2018 11:05 PM
Throwing P0171 and P1170 codes B-R-Z Software Tuning 39 01-27-2018 09:56 PM
P0171, P219a after OFH2 install phantasticity Engine, Exhaust, Transmission 2 09-10-2016 07:55 PM
