Old 01-11-2022, 03:38 PM   #1
BrZ_Good
Drives: '13 BRZ Ice Silver Metallic
P0301, P219A, P119F, P119E
Precursor to current issue. Went driving in NC mountains in sept, dropped fire to cylinder 4. Turned out to be leaky spark plug tube, shorted out plug and coil. Borrowed space in friends shop and pulled engine for new seals on both valve covers/tube seals. New plugs too. Put 200 miles on engine and notice a tick on exit ramp. Putt the car 20 miles up the road to parents and read current codes P0301, P219A, P119F, P119E. No longer ticking, rough idle, exhaust smells rich. Cylinder one actually has the new coil pack now, unplugged and reinstalled coil plug, pcv lines attached, brake booster attached. I only have top two DI computer bolts installed and read somewhere all 3 need to be installed for correct grounding. Any ideas?? I’m a noob to a lot, as well as code reading. How can I diagnose this? Valve rockers were all in place and cams looked good.
BrZ_Good is offline   Reply With Quote
Old 01-11-2022, 10:10 PM   #2
Grady
Grady's Avatar
Well that is a laundry list. Since you have a P0301 I would start with the #1 cylinder. Spark plug, coil, injectors. The other codes are mixture related and would be a symptom of #1 not firing.
I am curious to what you are calling a “leaky spark plug tube”. Can you elaborate?
Old 01-11-2022, 10:43 PM   #3
p1l0t
p1l0t's Avatar
Change the other 3 spark plugs?
Old 01-12-2022, 08:58 AM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
The DI is apparently grounded by the bottom bolt. Install that and see what happens. My car throws P0219a, P0119f, and occasionally P0304 after a rebuild. I replaced upstream 02, MAF, and MAP and checked for vacuum leaks. Datalogging shows fuel trims and AFRs are off but I don't know why yet. I'm taking it to PTuning on Friday. I'll let you know what I find.
Old 01-12-2022, 10:33 AM   #5
BrZ_Good
The gasket in between the valve cover and head that seals the spark plug well, on cylinder 4 for me. Replaced them all tho. New plugs all around when I put new gaskets on.
Old 01-12-2022, 10:41 AM   #6
BrZ_Good
I would appreciate a follow up. I just wanted to fix my oil leak lol, how’d this happen?!
The Following User Says Thank You to BrZ_Good For This Useful Post:
blsfrs (01-12-2022)
Old 01-12-2022, 10:45 AM   #7
BrZ_Good
I will try putting a bolt in the bottom of my di computer and see what happens
blsfrs (01-12-2022)
Old 01-12-2022, 12:50 PM   #8
BrZ_Good
No luck. Swapped coil and plug on 1 and 3. Still prominently throwing p0301. Guess I’ll pay to get the coil connector tested, pull the pan off and look at the injectors? Can they compression test without pulling the motor?
Old 01-13-2022, 08:52 AM   #9
blsfrs
blsfrs's Avatar
Compression test can be done without pulling the motor. You can DIY. Autozone or another parts store should have a kit that you can borrow. I tilted my engine by taking one mtr mount nut off and leaving the opposite one loose. Some folks take the fuel pump or injector fuses out. The are a couple of good video tutorials out there.
Old 04-14-2025, 02:00 PM   #10
KxngCorey
KxngCorey's Avatar
Drives: Hot Lava FR-S
Did you figure this issue out?
2015 Hot Lava FR-S IAG 800 FBM Turbo Kit
KxngCorey is offline   Reply With Quote
Old 04-16-2025, 10:33 AM   #11
blsfrs
blsfrs's Avatar
Not really. The tuner "adjusted" the ecu so the codes would show up. All the engine parameters were good.
Chech Engine Light On P219A P119E P0171 tonytduc Issues | Warranty | Recalls / TSB 4 09-21-2022 04:09 PM
P119F P219A + out of warranty ? zippee Issues | Warranty | Recalls / TSB 12 03-19-2021 12:32 AM
P219A, P119F - Air Fuel Ratio Imbalance hui202 Issues | Warranty | Recalls / TSB 14 08-16-2019 06:47 PM
P0302, p219a, p0352, p119f, used car woes. Dara321aaa Issues | Warranty | Recalls / TSB 8 04-29-2019 09:44 PM
Click/clanking sound w/ P219A, P119F, P0302 Kentoxik Issues | Warranty | Recalls / TSB 7 01-24-2019 09:23 PM
