Old 06-19-2025, 02:27 PM   #1
Devante
Crescent fresh at best.
Devante's Avatar
Drives: 2016 Scion FR-S - Asphalt
Door bolt replacement.
Heya,
Does anyone know what the size of the bolt holding the door ajar switch?
I want to replace it with a black one and I've tried M8-16mm and M6-16mm flange bolts and one is too big and one seems ever so slightly too small.
Any M7 I can find is left handed threads so wondering if anyone here knows.
Here's the bolt in question: https://i.imgur.com/IM8OGaj.png
Thanks for any info!
Devante is offline   Reply With Quote
Old 06-20-2025, 10:05 AM   #2
smackrel
Full Throttle!
Drives: 17 CBSP Limited PP
OR you could go to Home Depot/Lowes and remove it in the parking lot. Take it in and match it up with something.
But the OEM route is probably a better choice lol
smackrel is offline   Reply With Quote
Old 06-20-2025, 10:53 AM   #3
AJ32162
Drives: 2019 BRZ with Performance Package
I chemically changed the color of mine to black with gun rebluing liquid and a Q-Tip. They now look like the rest of the factory black bolts.
AJ32162 is offline   Reply With Quote
Old 06-20-2025, 12:46 PM   #4
smackrel
Full Throttle!
Originally Posted by AJ32162 View Post
I chemically changed the color of mine to black with gun reblueing liquid and a Q-Tip. They now look like the rest of the factory black bolts.
Well that sounds pretty dang serious.
Did you remove them or do it on the car?
Old 06-20-2025, 03:59 PM   #5
AJ32162
I did it on the car with a Q-Tip. The bluing liquid doesn't harm rubber or plastic. I've been using it for years to blacken bolt heads. It gives even coverage, the perceived "bare" spots in the photo are actually just glare from the camera flash and light oil applied after the curing.
The Following User Says Thank You to AJ32162 For This Useful Post:
bcj (06-21-2025)
Undid the wrong bolt for trans fluid (bottom bolt)... issues GrandSport Engine, Exhaust, Transmission 1 08-26-2024 08:07 AM
Perrin Oil Cooler - Mocal Plate Spacer Bolt - Damn Bolt Gopherboy6956 Engine, Exhaust, Transmission 16 11-23-2017 11:56 AM
Camber bolt + suspension bolt torque settings LostSalad DIY (Do-It-Yourself) Guides 3 05-09-2016 09:29 AM
Rear Sway Bar Stabilizer Bracket Bolt replacement? Books Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-19-2012 03:55 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
