Old 05-03-2025, 05:04 PM   #1
YgRoshi
YgRoshi's Avatar
Drives: 2017 86 MT BASE
Clunking noise at low RPMs in 1st & 2nd Gear?
Hey everyone, I've been hearing a sort of clunking noise when I drive in 1st & 2nd (no noise in 3rd-6th gear) at low rpms. Once the RPMs get high enough, the sound goes away, or if I've been driving the car for a while, like an hour or so, the sound also goes away even at low RPMs.
I brought it to the dealership and they inspected the entire under carriage but was not able to find anything making that noise.
I am suspecting that it might be the clutch? or something with the transmission? My vehicle is a 2017 Toyota 86 base MT, with 33,500 miles on it.
Any insight would be much appreciated, thank you in advanced!
YgRoshi is offline   Reply With Quote
Old 05-03-2025, 09:01 PM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Try to get a recording of the noise.
Old 05-04-2025, 06:33 PM   #3
YgRoshi
YgRoshi's Avatar
Here's the video link!
The Following User Says Thank You to YgRoshi For This Useful Post:
blsfrs (05-05-2025)
Old 05-04-2025, 08:37 PM   #4
norcalpb
norcalpb's Avatar
I had a similar noise when I removed my Whiteline transmission insert and failed to keep the transmission mount's metal center post straight when retightening. This was a very one-off situation though.
What mods have you done in the transmission area?
norcalpb is online now   Reply With Quote
Old 05-04-2025, 09:12 PM   #5
YgRoshi
YgRoshi's Avatar
I dont think i have any mods done around the transmission area. The only thing that was done under the car is an exhaust, front pipe, over pipe, an headers.
Old 05-05-2025, 09:50 AM   #6
norcalpb
norcalpb's Avatar
Double check the overpipe isn't hitting the front crossmember.
If possible, I'd try to mount a camera underneath the car to get a better sound sample of what's going on. I can hear the noise in your video but it's somewhat hard to make out.
Old 05-05-2025, 02:46 PM   #7
YgRoshi
YgRoshi's Avatar
I'll see if I can get a something to mount underneath the car while I'm driving, the car itself is pretty low already so that might be a no go. I'll definitely double check to make sure none of the pipes are hitting anything though, thank you!
Problem with 1st gear and 2nd gear!?!? Offwhite.86 Engine, Exhaust, Transmission 14 10-19-2020 11:37 PM
Clunky 1st gear and 2nd gear Sleepyyysam Issues | Warranty | Recalls / TSB 14 05-23-2018 04:51 PM
No 1st gear or 2nd gear sroby Issues | Warranty | Recalls / TSB 15 08-23-2016 07:40 PM
&&&&&&&&&&& zpeed Exterior Parts (Aero, Lighting, Etc.) 3 02-07-2016 12:15 PM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
