Old 05-22-2018, 08:32 PM   #1
Sleepyyysam
sleepy
Sleepyyysam's Avatar
Drives: Brz
Clunky 1st gear and 2nd gear
The other day I was driving around for quite awhile in 100 degree weather. I would say about two hours in traffic and freeway. I noticed the longer I drove the harder it was to engage my first gear almost like I was fighting the trans. I tried blipping the throttle a bit to get it into the gears but wasn't helping. I stopped by my dealership where I bought the car and they said it was just the short shifter that was installed from the person who owned it before me. Told me to take it out right away I'm ruining the syncros. This is what I'm really wondering... Is it my short shifter ? Because it seems unlikely my short shifter only had real problems when my car is very hot. My other theory is my trans temps are too hot and that's why I can't engage into first and second. Let me know what you guys think. Thank you all.
Sent from my Pixel XL using Tapatalk
Sleepyyysam is offline   Reply With Quote
Old 05-22-2018, 08:36 PM   #2
highway7
Drives: FRS 2013
I would try a trans fluid change, usually shifting gets easier as the fluid warms up
highway7 is offline   Reply With Quote
Old 05-22-2018, 08:39 PM   #3
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Are you properly rev-matching? 1st is notoriously difficult to get into while moving if you DO NOT properly rev match. People tend to underestimate how many RPMs 1st gear requires when downshifting. It's a short gear.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 05-22-2018, 08:40 PM   #4
Sleepyyysam
sleepy
Drives: Brz
I had just done one about 1000 miles ago with motul. Everything has been fine except for a couple times.
Old 05-22-2018, 08:42 PM   #5
Sleepyyysam
sleepy
Drives: Brz
I should have been more specific. Sorry, I'm terrible when it comes to this but I'm talking about just leaving from a stop. I can actually get into those gears from a roll with a bit or rev matching.
Old 05-22-2018, 08:53 PM   #6
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
yea definitely wouldn't be due to "high" temps, shifting on this box feels the best after it's warmed up...
what about going into 2nd first and then into 1st?
HKz is offline   Reply With Quote
Old 05-22-2018, 08:54 PM   #7
humfrz
Well, Sleepyyysam, maybe there is something to blaming the short shifter. I understand that sometimes they get lose and the gate plate thing gets out of line.
That might be worth checking out.
What do you think, there @Ultramaroon …..??
humfrz
Old 05-22-2018, 08:57 PM   #8
Sleepyyysam
sleepy
Drives: Brz
That's what I thought, at least that's usually the the opposite of the problem. I see a lot of cold problems on the forums. It's tough to get it into second also. I hate saying this but I can pull it hard enough to enter second then push it into first but they're equally tight regardless of which gear I put it into first from a stop.
Old 05-22-2018, 08:59 PM   #9
Sleepyyysam
sleepy
Drives: Brz
humfrz
Unfortunately I didn't install this short shifter so I'm not quite sure what to look for. I will go through this weekend and try to realign the first and second gear, as well as tighten down the gate plate. I'm really hoping it's just loose but what I don't understand is why it only acts up under heavy temps.
The Following User Says Thank You to Sleepyyysam For This Useful Post:
humfrz (05-22-2018)
Old 05-22-2018, 09:55 PM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
I assume you are referring to the TRD short shift adapter and not an actual short shift lever like the Kartboy.
If there is ANY play allowing the shift lever to rotate about the vertical axis, the adapter is loose. If that's the case, I recommend removing and tossing it into the nearest dumpster. I have a deep hatred for that piece of shit.
Sleepyyysam (05-23-2018)
Old 05-22-2018, 10:00 PM   #11
humfrz
Well, that's one way of "fixing" it ……..
humfrz
Ultramaroon (05-22-2018)
Old 05-23-2018, 01:13 AM   #12
Sleepyyysam
sleepy
Drives: Brz
Well boys, I ripped everything apart to try and see if something was broken and didn't really see much. I have to drive it to and from work so threw it all back together. Now the car is shifting perfect. As if nothing ever happened... I'm going to drive it harder than usual tomorrow and see if it's still working well. Maybe something wasn't aligned correctly? Either way thank you guys for the replies !
The Following 2 Users Say Thank You to Sleepyyysam For This Useful Post:
humfrz (05-23-2018), Ultramaroon (05-23-2018)
Old 05-23-2018, 02:18 AM   #13
humfrz
Well, let's hope it's "fixed"...…...
humfrz
Old 05-23-2018, 01:36 PM   #14
Ultramaroon
not playing cards
You mentioned the top plate alignment earlier so I skipped it. A couple people here ran into issues from neglecting that after installing a short shifter. If the previous owner was sloppy, I can imagine a marginal alignment causing trouble after thermal expansion, blah blah...
There's a procedure in the manual which involves feeler gauges but it's kind of overkill. The middle of the gates are easy enough to feel by hand.
Anyone feel like they have a clunky gear change? Haseebali31 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 04-16-2022 02:52 PM
Clunky and hard gear shifts nhuyvan1106 Issues | Warranty | Recalls / TSB 45 08-26-2017 01:52 PM
Gear indicator (G-on) shows 2 when in 3rd gear c8Face BRZ First-Gen (2012+) — General Topics 31 07-07-2017 07:23 PM
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 06:28 PM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
