Old 02-04-2025, 12:46 PM   #1
Katore
Drives: Red Scion FR-S turbocharged
Valve cover gasket guide?
Anyone know of a diy guide on the valve cover/ spark plug gaskets?
Got doo doo on the spark plugs so going to be pulling the motor and re sealing. Looking for a write up describing the process. Also I need part numbers for all the gaskets
Also re sealing timing cover because of a small leak while i have the motor out. Anything else that should be done at the same time?
Katore is offline   Reply With Quote
Old 02-08-2025, 04:32 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I thought about doing a video guide but didn’t have time. The manual is a pretty good source.
I would pass on the timing cover if you can. Find the leak, clean and degrease, then see if you can get away with smearing some RTV over the leak. The timing cover is a PITA.
Help me find a valve cover gasket video? daniloneil8 Scion FR-S / Toyota 86 GT86 General Forum 10 09-14-2024 09:13 PM
Valve cover gasket replacement knucklehead Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 05-06-2021 06:38 PM
Driver side valve cover gasket leak solidONE Issues | Warranty | Recalls / TSB 59 02-22-2021 12:52 AM
Other Oil leaks - Oil Pan gasket? - NOT Cam plate, valve cover, or Cam cover exE36M3 Issues | Warranty | Recalls / TSB 17 11-08-2017 10:15 AM
Valve Stem Gasket VIP BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 12-28-2016 06:57 PM
