Old 09-25-2024, 06:17 PM   #1
custardbun
Drives: 2014 Toyota 86 GTS
Metal in oil - what next?
I’ve got a 2014 86 I’ve had for 10 years since it was new. Engine mod wise it’s got headers and an ecutek tune and a water/oil style oiler cooler but engine is otherwise pretty stock. From time to time over the years I’ve seen very small amounts of metal in the oil but nothing concerning, a tiny fleck here or there. About 1000km ago there was a bit more that usual that had me concerned.
I do the occasional track day, once or twice a year, and I’m pretty careful with the car. I always use full synthetic 5w-30 on the track, and even mostly driving around town.
Photos are here: https://imgur.com/a/z5xSJjm
I opened the filter and it was clean, I changed the oil, drove it another 1000km, changed the oil again (this time by a mechanic) and have got an oil analysis done. The oil analysis came back normal.
Where to from here? Anyone experience similar issues? I’m at a loss on what to do?
custardbun is offline   Reply With Quote
Old 09-25-2024, 06:59 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Used oil analysis would be a good idea.
Old 09-25-2024, 07:41 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Keep driving and submit another sample from the same fill after a few thousand miles. Look for changes.
Old 09-25-2024, 07:54 PM   #4
custardbun
Do you mean with more than 1000km on it? I’ll change it after a bit longer next time an do another one.
Old 09-25-2024, 08:54 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Put some time on the current oil change and do one like Ultra said above. It doesn’t have to be an end of service interval change but you want some miles. They will be able to tell you what kind of metal is in it and if it is higher then it should be.
Old 09-25-2024, 09:45 PM   #6
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
You might use a magnetic oil plug too.
Old 09-27-2024, 10:59 AM   #7
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
5w30 seems a little light to me for track use, even though you have an oil cooler.
Qwimby1 is offline   Reply With Quote
Old 09-28-2024, 09:43 AM   #8
custardbun
What would you recommend?
Old 09-28-2024, 10:34 AM   #9
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
I`m sure he will say 5w-40.
gen3v8 is offline   Reply With Quote
Old 09-29-2024, 12:45 AM   #10
Ultramaroon
not playing cards
...a water/oil style oil cooler
Is it the JR radiator, by chance?
Old 09-29-2024, 09:15 AM   #11
custardbun
No it’s just the Cusco GR86/Forester style cooler.
Old 10-02-2024, 10:07 AM   #12
Qwimby1
I think some use straight 40w. I haven't tracked mine so I can't speak from personal experience. Is that forester cooler as robust as something like a Perrin? What temps are you running on track?
Old 10-04-2024, 04:45 PM   #13
custardbun
The 2 in 1 temp and pressure gauge I’ve got codes show a straight temp reading, just a light bar around the circumference of the gauge in green, orange and red. I’ve got it set to 120 degrees Celsius for hitting the red, so I know when I hit that, I’ve got about 1 lap before a cooldown but I understand a good synthetic oil will be able to handle that pretty well. I’m really monitoring the pressure more than the temp. I’ve never noticed any issues with pressure.
As for the robustness of the cooler, I think it’s probably good for about 5 degrees Celsius cooler temps overall based on manufacturer spec. The reason I got it was because I didn’t want to have to block the radiator or cut out the fog light in the bumper for an air oil cooler.
engine, oil change engine damage
Metal in oil Antisocialspeed Engine, Exhaust, Transmission 17 10-09-2019 11:10 PM
metal on metal sound when releasing the clutch MyNave Engine, Exhaust, Transmission 7 04-18-2018 12:00 AM
Metal on metal noise at 2500 RPM ssyed Issues | Warranty | Recalls / TSB 2 09-08-2014 04:01 PM
Metal on metal scratching noise front left wheel Ezk1el Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-11-2014 12:00 AM
I've seen the GT86 in the metal and... Craikeybaby Scion FR-S / Toyota 86 GT86 General Forum 37 12-13-2011 03:57 AM
