Drives: 2017 Series.yellow BRZ
Advice needed on stuck caliper bolt
I have a 2017 with the Brembo calipers. I'm trying to change the rotors. The upper bolt on the front calipers comes out without any problem. The lower on the passenger side comes out a bit then stops. The driver side won't turn at all. I've tried penetrating oil around the joint and even around the back with a belt straw. I've tried heat on the caliper also. I can see the head of the bolt turning but if use anymore force it will twist or break.
Has anyone else had this problem? How can I get the bolt free? Thanks |
| Caliper union bolt specs? | Chuckable | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 06-25-2020 07:06 PM |
| Suspension bolt stuck? | Rubedo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 05-24-2020 11:18 PM |
| Please identify this bolt from 4 pot caliper (WRX) | FT86Z | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 08-10-2018 09:41 AM |
| Drivers side Brake caliper stuck shut? ABS engaged all the time. | gdrider77 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 09-20-2015 09:02 PM |
| Front Caliper Bolt Pattern | kmbkk | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 11-08-2012 11:21 AM |
