Old 08-23-2012, 08:33 PM   #1
_F-R-S_
Drives: 13 whiteout scion frs
Noob to wheels! :(
So im going to be ordering Sparco Assetto 17"x8 and was wondering should i stick with the recommended tire size of 225/45/17. i mean will that be flush with the back and front? i will be doing some autox. seems like the perfect size imo.. thanks for the help!
_F-R-S_ is offline   Reply With Quote
Old 08-23-2012, 08:37 PM   #2
boucher
Leaux Down Krewe
boucher's Avatar
Drives: 2014 SSM Limited
225 is the "right" size for 8" wheel but you could run 235's, maybe 245's depending on brand, and be fine (better for autox). As far as "flush", that's an issue of your wheel offset. I don't know what offset makes you flush on this car yet, but I do know that it will be staggered. I think there is sticky with offset information.
boucher is offline   Reply With Quote
Old 08-24-2012, 03:00 AM   #3
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
For autox i wouldn't worry about being flush, you could run spacers on the back on the street if you want it to look more flush.
JoeBoxer is offline   Reply With Quote
Old 08-24-2012, 08:43 AM   #4
Coaster
Coaster's Avatar
Drives: Civic
I will be getting those wheels too. Tirerack only has 17 *7.5 and 18 for the car. Where are you getting the 17*8 from?
Coaster is offline   Reply With Quote
Old 08-24-2012, 09:41 AM   #5
BAE
BAE's Avatar
Drives: BRZ Ltd WRB
I drive 225/45-17 on 17x8. If you plan to Autocross I would definitly go to 235/40-17. You get 10 mm wider tires and more sideways grip, the gearing is slightly better and for the most popular AutoX tire, Dunlop Starspecs the 235/40 is 2 lbs lighter than the 225/45. Others may tell you that is worth going to 245s as well. I would guess you sacrifice some steering feel if you put 245s in front of this light car.
Enkei RPF1/K&N/Perrin crank pulley/Visconti Stg1/Perrin catback and overpipe/KW V3
BAE is offline   Reply With Quote
Old 08-24-2012, 10:17 AM   #6
Coaster
Coaster's Avatar
Drives: Civic
I hope to mod the car to about 250-270 HP should I go with 235's or stay with 225. I only will use the car for the street.
Thanks.
Old 08-24-2012, 10:55 AM   #7
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
you'll want more tire if possible to handle more hp. I'd go 235's over 225's all day long. To be honest.. if you got up to 270hp.. you'd probably want 245's.
eikond is offline   Reply With Quote
Old 08-24-2012, 11:18 AM   #8
BAE
BAE's Avatar
Drives: BRZ Ltd WRB
I wouldn't be afraid to go to 235's. It looks better too. It was two reasons why went for 225's. I was eager to try the Michelin Supersports and they don't come in 235/40, and the place I plan to export the car, wide tires on a light car is bad due to a lot of tracks in the roads.
For street driving and looks, a staggered setup could be nice, e.g. 225 Front + 255 Rear
Old 08-24-2012, 08:17 PM   #9
_F-R-S_
Yea sorry was thinking of another wheel at the time..
Thanks!! very helpfull information!
Noob to this. Style Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-09-2012 08:10 PM
Noob how often do you check you oil Fugazi Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 07-06-2012 05:58 PM
Noob question fitcious Cosmetic Modification (Interior/Exterior/Lighting) 2 05-02-2012 11:18 PM
Noob to the forum! Altezza_86 Off-Topic Lounge [WARNING: NO POLITICS] 14 12-19-2011 05:34 PM
