Old 02-13-2024, 11:47 AM   #1
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
Fuel Leak repair costs
HOOLLEEEE CRAP! Talk about sticker shock… This is the estimate to repair a fuel leak on my 2018 BRZ tS garage queen. A car I might add which has only covered 28,885 kilometers from new. And of course it is now out of Power Train warranty. (Not that it would have been covered as I’m sure they would have found a way out of that…)
The real kicker is, after waiting almost eight weeks to get this diagnosis some of the parts are on back order. Now the car is sitting at the dealership for who knows how long. I have a buyer for it but he can’t even test drive it now.
PLUS, this estimate is not the final cost nor does it include the 2 hours of diagnostic labour.
Now, which part actually caused the leak? Why replace all these parts? And what about the right hand side?
Request Description Job Type
OTHER4 REPLACE LEFT FUEL RAIL TWO LINES AND INJECTOR O-RINGS 1 C
Labour Description CSR Amount
OTHER4 REPLACE LEFT FUEL RAIL TWO LINES AND INJECTOR O-RINGS 16048 539.80
Part Part Description Req Price Amount
17523AB010 PIPE ASSY-FUEL LH 1 367.71 367.71
17540AA340 PIPE AY-FUEL DLVY 1 63.98 63.98
17555AA040 GSKT-FUEL PIPE 1 7.14 7.14
14035AA720 GSKT-INT MANIF 2 23.26 46.52
15194AA450 SCR-UNION 1 11.34 11.34
17540AA330 PIPE AY-FUEL DLVY 1 108.50 108.50
16677JB010 RING-BACK UP 2 6.45 12.90
16608JB010 SEAL-FUEL INJ 2 8.58 17.16
16608JB000 SEAL-FUEL INJ 2 9.92 19.84
Request Total 1,194.89
Labour 539.80
Parts 655.09
Supplies 0.00
Env Fee 0.00
Sub-Total 1,194.89
HST 155.34
Total Estimate 1,350.23
Old 02-13-2024, 12:34 PM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Can you see the leak? Or just smell gas? Sounds like they are just throwing parts at it hoping something sticks.
The Following User Says Thank You to blsfrs For This Useful Post:
whataboutbob (02-13-2024)
Old 02-13-2024, 02:17 PM   #3
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Rodent damage?
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 02-13-2024, 08:04 PM   #4
Grady
Grady's Avatar
I ran a couple of pipe part numbers and there is no reason to replace those. Unless they were damaged during removal. maybe one of them has a crack but all of them seem suspicious.
The Following 2 Users Say Thank You to Grady For This Useful Post:
blsfrs (02-13-2024), whataboutbob (02-13-2024)
Old 02-13-2024, 11:31 PM   #5
whataboutbob
AutoX-10/10ths every run
Where is the gas leaking from? That seems like a LOT of parts.
Build thread:Here
Old 02-14-2024, 12:33 AM   #6
Stephen W.
Stephen W.'s Avatar
I did not get a lot of info. I’ll try and get the full story because yeah, that seems like a lot of parts. I was thinking it’s just an injector O ring and it’s spraying a fine mist over the fuel rail. That’s why they didn’t pin point the actual leak when the car was in three weeks ago. I haven’t seen any signs of rodents in the garage in a couple of years. That’s not to say it is not them lil’ beggars chewing on stuff. But if it was wouldn’t the Service Manager tell me that?
Old 02-14-2024, 08:53 AM   #7
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Your car is completely unmolested, right?
This just doesn't sound right.
Stephen W. (02-14-2024)
Old 02-14-2024, 08:51 PM   #8
SuperSub7
Drives: Awesome
Are you able to see the leak visually? Sounds a little weird to me.
SuperSub7 is offline   Reply With Quote
Old 02-14-2024, 10:39 PM   #9
Stephen W.
Stephen W.'s Avatar
I have a Greddy cat back and that's all. And no, I couldn't see anything myself. It took the tech sometime and I think he had it up on the hoist at one point. They told me it was around the fuel rail but wouldn't know exactly what until they had the car tore down. Still confusing as all heck!
Old 02-14-2024, 10:57 PM   #10
whataboutbob
Low pressure or high pressure fuel rail?
Low pressure has gaskets on bottom and top of port injectors.
High pressure would be surprise if it has never been touched.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
alphasaur (02-15-2024)
Old 02-15-2024, 11:22 AM   #11
alphasaur
friendly
Drives: 17' 86
If it's highpressure fuel rail intake manifold has to come off, which is kinda labor intensive (I'd guess for a tech that has done it a bunch it's 3ish hours for removal and replacement)
Low pressure does not need IM removal
edit: looked up parts and looks like they're replacing DI seals. This quote seems about right as it's fairly labor intensive and a lot of those gaskets are one time use.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
The Following User Says Thank You to alphasaur For This Useful Post:
Stephen W. (02-15-2024)
Old 02-15-2024, 01:15 PM   #12
Stephen W.
Stephen W.'s Avatar
Just talked with Subaru’s service department. The fuel lines are one time use items also. While it's apart the tech thought it a wise move to replace the seals as they are prone to failure. What is not known to ever fail (unless someone did something) but did in my case is the fuel rail. So I asked; would Subaru have covered this under the power train warranty if it had happened during the warranty period? Service said probably. So I have asked them to request an after warranty adjustment claim because this car is so well kept and very low mileage. Plus, we own two Subaru’s at present and have owned 5 previously. Cross our fingers that we get this after warranty adjustment.
Oh... and of course it's the fuel rail that is on back order. Why? Because they never fail!
The Following 4 Users Say Thank You to Stephen W. For This Useful Post:
alphasaur (02-15-2024), bcj (02-15-2024), blsfrs (02-15-2024), x808drifter (02-15-2024)
Old 02-15-2024, 03:17 PM   #13
Grady
Grady's Avatar
Buy a set of these!
https://www.radiumauto.com/Fuel-Rail...GR86-P390.aspx
Old 02-20-2024, 12:35 PM   #14
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I re-used all the full rails when installing my SC. Did use new seals of course. Edelbrock’s instructions were to re-install the rails.
Thousands of kilometres of happy motoring since.
Note: the factory service manual often suggests replacing non wear parts which are perfectly fine to re-use. Dealer mechanic’s comply. Independent shops not so much.
If you are up to doing the job yourself you would save many $’s.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
The Following User Says Thank You to Muskoka800 For This Useful Post:
Stephen W. (02-20-2024)
FRS Rod Knock - Estimated Repair Costs FR & S Scion FR-S / Toyota 86 GT86 General Forum 17 01-22-2023 04:16 AM
Dealer fuel filter replacement costs? Laz84 BRZ First-Gen (2012+) — General Topics 9 06-04-2020 03:16 PM
Estimated costs for out of warranty repair work? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 03-24-2016 03:03 PM
Repair Costs discretion Scion FR-S / Toyota 86 GT86 General Forum 29 11-24-2015 11:27 PM
OIL LEAK REPAIR | FRS BRZ JPxM0Dz Engine, Exhaust, Transmission 1 02-20-2014 11:12 AM
