Drives: 1993 Caterham HPC Evo
Fuel Leak repair costs
HOOLLEEEE CRAP! Talk about sticker shock… This is the estimate to repair a fuel leak on my 2018 BRZ tS garage queen. A car I might add which has only covered 28,885 kilometers from new. And of course it is now out of Power Train warranty. (Not that it would have been covered as I’m sure they would have found a way out of that…)
The real kicker is, after waiting almost eight weeks to get this diagnosis some of the parts are on back order. Now the car is sitting at the dealership for who knows how long. I have a buyer for it but he can’t even test drive it now. PLUS, this estimate is not the final cost nor does it include the 2 hours of diagnostic labour. Now, which part actually caused the leak? Why replace all these parts? And what about the right hand side? Request Description Job Type OTHER4 REPLACE LEFT FUEL RAIL TWO LINES AND INJECTOR O-RINGS 1 C Labour Description CSR Amount OTHER4 REPLACE LEFT FUEL RAIL TWO LINES AND INJECTOR O-RINGS 16048 539.80 Part Part Description Req Price Amount 17523AB010 PIPE ASSY-FUEL LH 1 367.71 367.71 17540AA340 PIPE AY-FUEL DLVY 1 63.98 63.98 17555AA040 GSKT-FUEL PIPE 1 7.14 7.14 14035AA720 GSKT-INT MANIF 2 23.26 46.52 15194AA450 SCR-UNION 1 11.34 11.34 17540AA330 PIPE AY-FUEL DLVY 1 108.50 108.50 16677JB010 RING-BACK UP 2 6.45 12.90 16608JB010 SEAL-FUEL INJ 2 8.58 17.16 16608JB000 SEAL-FUEL INJ 2 9.92 19.84 Request Total 1,194.89 Labour 539.80 Parts 655.09 Supplies 0.00 Env Fee 0.00 Sub-Total 1,194.89 HST 155.34 Total Estimate 1,350.23 |
#2 |
Drives: 2013 frs base
Can you see the leak? Or just smell gas? Sounds like they are just throwing parts at it hoping something sticks.
| The Following User Says Thank You to blsfrs For This Useful Post: | whataboutbob (02-13-2024) |
#3 |
Drives: 2020 GMC Canyon Denali Diesel
Rodent damage?
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
#4 |
I ran a couple of pipe part numbers and there is no reason to replace those. Unless they were damaged during removal. maybe one of them has a crack but all of them seem suspicious.
| The Following 2 Users Say Thank You to Grady For This Useful Post: | blsfrs (02-13-2024), whataboutbob (02-13-2024) |
#5 |
AutoX-10/10ths every run
Where is the gas leaking from? That seems like a LOT of parts.
#6 |
I did not get a lot of info. I’ll try and get the full story because yeah, that seems like a lot of parts. I was thinking it’s just an injector O ring and it’s spraying a fine mist over the fuel rail. That’s why they didn’t pin point the actual leak when the car was in three weeks ago. I haven’t seen any signs of rodents in the garage in a couple of years. That’s not to say it is not them lil’ beggars chewing on stuff. But if it was wouldn’t the Service Manager tell me that?
#7 |
Famous Potatoes
Drives: '15 ultramarine
Your car is completely unmolested, right?
This just doesn't sound right. |
| The Following User Says Thank You to Sapphireho For This Useful Post: | Stephen W. (02-14-2024) |
#8 |
Drives: Awesome
Are you able to see the leak visually? Sounds a little weird to me.
#9 |
I have a Greddy cat back and that's all. And no, I couldn't see anything myself. It took the tech sometime and I think he had it up on the hoist at one point. They told me it was around the fuel rail but wouldn't know exactly what until they had the car tore down. Still confusing as all heck!
#10 | |
Low pressure or high pressure fuel rail? Low pressure has gaskets on bottom and top of port injectors. High pressure would be surprise if it has never been touched.
| The Following User Says Thank You to whataboutbob For This Useful Post: | alphasaur (02-15-2024) |
#11 |
friendly
Drives: 17' 86
If it's highpressure fuel rail intake manifold has to come off, which is kinda labor intensive (I'd guess for a tech that has done it a bunch it's 3ish hours for removal and replacement)
Low pressure does not need IM removal edit: looked up parts and looks like they're replacing DI seals. This quote seems about right as it's fairly labor intensive and a lot of those gaskets are one time use.
Seek comfort in discomfort.
| The Following User Says Thank You to alphasaur For This Useful Post: | Stephen W. (02-15-2024) |
#12 | |
Oh... and of course it's the fuel rail that is on back order. Why? Because they never fail! |
| The Following 4 Users Say Thank You to Stephen W. For This Useful Post: |
#13 | |
https://www.radiumauto.com/Fuel-Rail...GR86-P390.aspx |
#14 |
Drives: 2016 Scion FRS Release Series 2#439
I re-used all the full rails when installing my SC. Did use new seals of course. Edelbrock’s instructions were to re-install the rails.
Thousands of kilometres of happy motoring since. Note: the factory service manual often suggests replacing non wear parts which are perfectly fine to re-use. Dealer mechanic’s comply. Independent shops not so much. If you are up to doing the job yourself you would save many $’s.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) |
| The Following User Says Thank You to Muskoka800 For This Useful Post: | Stephen W. (02-20-2024) |
| FRS Rod Knock - Estimated Repair Costs | FR & S | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 01-22-2023 04:16 AM |
| Dealer fuel filter replacement costs? | Laz84 | BRZ First-Gen (2012+) — General Topics | 9 | 06-04-2020 03:16 PM |
| Estimated costs for out of warranty repair work? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 03-24-2016 03:03 PM |
| Repair Costs | discretion | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 11-24-2015 11:27 PM |
| OIL LEAK REPAIR | FRS BRZ | JPxM0Dz | Engine, Exhaust, Transmission | 1 | 02-20-2014 11:12 AM |
