| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2014 BRZ, 1991 Prelude Si 4WS
Dealer fuel filter replacement costs?
Does anyone know the ballpark pricing to have this service performed? Im at the Replace interval in the book.
My owners manual says replace at 75k.
But it also says “clutch operation” at 75k as well? What do? Last edited by Laz84; 07-17-2018 at 11:27 PM. |
Drives: Subaru BRZ
Neither need to be replaced until they start showing signs of problems, regardless of mileage. The owners manual is based on tests the manufacturer has done on the car and doesnt accurately represent real world driving.
| The Following User Says Thank You to Brz_racer For This Useful Post: | Busybee (05-28-2020) |
#5 | ||
Although this may be the case for the fuel filter, some of the items it should be done way sooner like transmission fluid etc. Its a decent estimate as to when to change things if not sooner. The service intervals are mostly based on life expectancy and degradation of fluids or wear at an "average" use scenario Quote:
https://www.ft86club.com/forums/showthread.php?t=99041 For our cars unless you begin to have performance symptoms common to a clogged filter, it's not necessary. Modern fuels and pumps have much less issues with blockages than they used to, probably something to do with tank design quality and how the fuel is stored.
[insert cool phrase here]
Drives: BRZ Premium
You can do it yourself and save money. YouTube it.
The fuel pump looks complicated but it's like legos, a couple of smaller parts that make up the unit. But like others said you don't need to replace it, be ok if you did but it's your wallet.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Drives: Scion FR-S 2013 White
I've seen a lot of people ask about pricing on the fuel filter topic. I too noticed the suggestion for fuel filter replacement at 75K in my manual. My 2013 FRS is at the dealer currently because I can' t get a drop of gas in it so I asked them to scope the filler neck and check the Fuel filter. They claim the neck looks good and that the fuel filter should last the life of the vehicle but would cost $213 to replace. They believe the issue is the charcoal canister, and I'm looking at 1100 for the canister, $300 for the neck (if I want that added on) and $213 for the fuel filter. I just want some consistency in this information
Drives: 2020 GMC Canyon Denali Diesel
Charcoal canister is the likely culprit. Fuel filter should only be changed if you are serving the pump for another reason or having issue.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Imperator
Drives: Supercharged 2013 BRZ Limited
I got one of these DW fuel pumps as a replacement. They're pretty cheap and come with installation instructions.
ft86speedfactory.com/deatschwerks-dw300-series-fuel-pump-w-install-kit-2015-wrx-2013-ft86.html#.XtigKTpKguU |
#10 |
Drives: 2014 FR-S
Check out your 8-year Federally required emission system warranty. Most of these parts should be covered. Specified major emission control components are covered for the first 8 years or 80,000 miles
| DIY: Drop-in Air Filter Replacement | Rabble | DIY (Do-It-Yourself) Guides | 68 | 09-01-2022 07:12 PM |
| non-dealer key replacement options | Shanahan | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 02-23-2017 03:33 PM |
| Air Filter Replacement | Shaisters | Northwest | 6 | 05-13-2014 06:39 PM |
| Simple drop-in filter replacement? | CaptainSlow | Engine, Exhaust, Transmission | 3 | 04-22-2013 11:41 PM |
