Old 12-12-2023, 04:27 PM   #1
jaygushi
jaygushi's Avatar
Drives: 2015 Scion FR-S Release series 1.0
Diff Fluid Leaking after Axle and Axle Seal Replacement
My car currently is leaking what appears to be diff fluid near the passenger side drive axle and diff axle seal. Anyone have any experience on what might be the issue?
A week ago (12/2), my driver side axle was making clicking noises on hard right hander turns so I replaced both side axles because I might as well replace both while I'm at it. (I used new ebay axles) When replacing my passenger side CV axle, an elastic metal spring-like band came out the diff which I later learned that is part of the axle seal (I think I may have damaged the axle seal when prying the axle out from the diff). I applied high temp grease on both axle splines and I reinstalled a new axle without the band and a couple days later I found diff fluid leaking in my garage floor.
Since I suspected this was an axle seal issue, on (12/8), I sourced 2 axle seals (2 just in case I break one again), took passenger side axle out and made sure I punched in the new axle seal against the metal blacking completely flush (punched with old axle seal sandwiched on top so I'm not hammering new part). Drained diff fluid (thankfully a lot came out, looked like I haven't leaked a substantial amount) and refilled with Motul 75w90
A day later while I was running sessions at the track I found out that I am leaking what appears to be diff fluid again (could it be leaking and stopped doing more sessions. I say appears to be because maybe it could be the grease from cv boot, but I'm not entirely sure. Lack of heat protection from TRD exhaust to diff? Improper installation of axle seal?
TLDR: Replaced both side axles -> passenger diff side leaking -> suspected damaged axle seal -> replaced new axle seal -> still leaking
Attaching pictures for reference. Any help is appreciated. Thank you.
jaygushi is offline   Reply With Quote
Old 12-13-2023, 08:48 AM   #2
whataboutbob
AutoX-10/10ths every run
I suspect the new seal is damaged. I had a similar problem in the past and ended up taking mine to a shop to have the seal replaced. There's a spring that holds the seal against the axle that can be damaged/deformed when installing the axle. If that happens you'll get a leak like this.
Build thread:Here
Old 12-14-2023, 04:13 PM   #3
jaygushi
jaygushi's Avatar
Yeah my origninal old seal lost its spring and when I replaced the new axle seal made sure that was intact.
I did however, not lube the inside nor seal the outside of the axle seal to the diff with RTV (not sure if this is necessary, but this video states so ->
When putting the new axle seal back in, I also used the old axle seal to tap it inside to not damage the new seal, but I do think I may have pushed in too far in. I pushed in to the point where it is flush against the shiny metal inner ring of the diff.
Really puzzled what the issue is, but thank you for your insight.
Old 12-21-2023, 01:53 PM   #4
M0nk3y
RTV isn't necessary for install.
You could have also damaged the seal itself while installing the new axle. That's how I damaged mine first go around and woke up the next day to a puddle of diff fluid.
IMO - Pull the axle and replace it again
Kyle H. - #89 STX
INSTALLED NEW AXLE: LEAKING DIFF FLUID? Bencauley8007 Issues | Warranty | Recalls / TSB 17 09-17-2024 02:48 PM
Leaking diff. At pinion seal, after replacing Throwout Bearing dc2stud Engine, Exhaust, Transmission 7 02-19-2020 05:23 PM
Rear Axle is stuck in diff neroman98 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-26-2018 01:45 PM
Leaky axle/diff seal? slyphen Issues | Warranty | Recalls / TSB 28 03-01-2018 01:30 PM
Axle Leaking Grease 636 Engine, Exhaust, Transmission 14 07-20-2017 08:09 PM
