Old 04-10-2017, 11:15 PM   #1
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
Leaky axle/diff seal?
So while swapping out my diff fluid, i spotted some oil residue on my rear passenger side axle. anyone know if this is normal? if not, does warranty cover it? thanks guys!
slyphen is offline   Reply With Quote
Old 04-10-2017, 11:32 PM   #2
humfrz
If you still have your powertrain warranty coverage, I reckon it would be covered.
However, with that small bit of oil/grease I wouldn't worry about it.
But, you may wish to keep an eye on it.
humfrz
Old 04-11-2017, 12:19 AM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Did you push your axles all the way back in?
Old 04-12-2017, 12:19 AM   #4
humfrz
.......he just swapped the differential fluid ......
Best to slow down with the speed reading .......as you get older .......
humfrz
Old 04-12-2017, 02:55 PM   #5
mav1178
mav1178's Avatar
haha I know... but this car has a tendency to have axles pop out if it's lowered or if the rear suspension is compressed too much.
Just an observation since it may happen.
Old 04-12-2017, 03:38 PM   #6
humfrz
......OK, you talked your way out of it ........this time ........
humfrz
Old 04-12-2017, 03:48 PM   #7
mav1178
mav1178's Avatar
humfrz
haha I only mentioned it because this exact situation happened to me.
Had some rear arms tested and then the axles popped out, leaked half my diff oil out onto the rear end of my car.
Old 04-12-2017, 04:10 PM   #8
DAEMANO
Time Traveller
If you still have a warranty, get it looked at. An afternoon at the dealer could save $1500 worth of ring and pinion or LSD repairs. At the very least, they will top you off on diff fluid and give you some piece of mind.
Old 04-12-2017, 04:32 PM   #9
mav1178
mav1178's Avatar
Except OP is lowered, and this will be one of those situations where they won't even bother if the car is lowered enough to cause axle seal issues.
The "lowered enough" part is up for interpretation, obviously.
-alex
Old 04-12-2017, 05:22 PM   #10
DAEMANO
Time Traveller
-alex
Lowered on dealer installed springs would still be under warranty. Or OP could swap back his OEM suspension (that'd be his call). It is up for interpretation, but in my book it's better to be safe than very sorry. Surely someone telling him to not have the leak checked out is being a tad reckless with someone else's car & money.
Old 04-12-2017, 06:21 PM   #11
mav1178
mav1178's Avatar
Well, OP is lowered on KW V3 and I have a feeling the axle popped out at some point. Not enough for a bad leak but enough for a small leak.
Takes about 30 seconds to fix.
Old 04-12-2017, 06:38 PM   #12
mav1178
mav1178's Avatar
Actually, after looking at it closer, the seal may just be slightly leaking over time.
Honestly, with the coilover installed and whatnot, you are not going to find an easy time to have this covered under warranty unless a dealer is willing to help you out on the paperwork. This is one of those situations where the modifications on the car may have caused or contributed to the leak, and you can't really say that the coilovers did NOT cause the leak.
Good luck.
-alex
Old 04-12-2017, 07:08 PM   #13
e1_griego
e1_griego's Avatar
Drives: Many
It's a cheap seal and pretty easy to replace. I got mine from frsport for ~$15.
e1_griego is offline   Reply With Quote
Old 04-12-2017, 09:27 PM   #14
slyphen
Drives: Man
what do you mean by popped out? how do you fix it?
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Transmission won't engage any gears.. Diff/Axle is done. Rifle Issues | Warranty | Recalls / TSB 35 03-29-2016 12:36 PM
Rear Diff axle removal xsnapshot Engine, Exhaust, Transmission 11 01-08-2016 12:28 PM
Diff whine with clutch engaged + axle seepage Laika Issues | Warranty | Recalls / TSB 33 10-11-2014 08:16 PM
Possible Leaky Taillight Fix Sco2355 Issues | Warranty | Recalls / TSB 6 02-18-2013 02:26 PM
