Old 11-13-2023, 08:45 PM   #1
Open Loop
2013 FR-S Whiteout / SSC
Part numbers for rear subframe and rear diff mounts?
Hi everyone,
I am interested in replacing all the rear subframe and rear differential bushings in my 2013 FR-S. Due to the class I am racing in, they need to be OEM. Has anyone developed a list of yhe part numbers for yhese bushings, or have a suggestion as to how I can efficiently identify the part numbers I need for all of these bushings?
Thank you!
Open Loop is offline   Reply With Quote
Old 11-13-2023, 10:30 PM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I typically use parts.subaru.com to look up the Subaru parts numbers if I want to order them from a wholesaler. You could also have the parts counter at a Toyota dealership look them up for you, but I typically just get the Subaru part for less money. Diff bushings for a 2013 brz can be found here:
https://parts.subaru.com/showAssembl...sembly=6029068
Haven't found part numbers for the subframe bushings themselves, I think typically they come pre-installed in a new subframe since you have to remove it to press in/out anyway.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
Old 11-13-2023, 10:35 PM   #3
norcalpb
norcalpb's Avatar
I’m 95% certain that a new subframe will come with all bushings, including the rear (cradle) differential bushings.
The front bushings do not come with the subframe but just so you know there have been a couple revisions for those.
But regardless:
Subaru provided subframe: 20152CA001
Toyota provided subframe: SU003-00349
They are the same thing.
Old 11-13-2023, 10:36 PM   #4
norcalpb
norcalpb's Avatar
I knew someone was gonna beat me to it
Old 11-14-2023, 10:59 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Originally Posted by Open Loop View Post
Hi everyone,
Thank you!
I have both of the rear diff-to-subframe bushings, OEM for sale if you are interested. PM me.
I bought them for my car ways back but never got around to using them. Brand new still bagged, for sale post here: https://www.ft86club.com/forums/showthread.php?t=148338
EndlessAzure is offline   Reply With Quote
Video and short review on the Cusco Engine Mounts and Rear Diff Brace RallySport Direct Engine, Exhaust, Transmission 24 07-23-2018 03:43 AM
PBM Solid Diff and Subframe mounts install Thebadvibes__ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 05-23-2017 01:04 AM
Part numbers for rear LCA bolts 7c8 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-12-2016 12:41 AM
Solid Aluminum Rear Subframe & Diff Bushings Carolina Dyno Tracking / Autocross / HPDE / Drifting 2 10-22-2015 10:00 PM
Rear diff subframe bolt type? Manji Engine, Exhaust, Transmission 1 03-19-2015 11:29 PM
