Old 03-12-2015, 04:40 PM   #1
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
Rear diff subframe bolt type?
I'm putting my diff back in tomorrow and fucked if I can find the bolts for it.
Does anyone know the size, pitch, length of them?
As per the pic, its the 3 bolts that go in the back through the bushing NZ part number 41110
I'd just go to Toyota usually, but they're out of stock here and in Japan. 4 weeks wait time. So I'd rather just go down to local bolt place and buy some.
Manji is offline   Reply With Quote
Old 03-19-2015, 11:29 PM   #2
Manji
Manji's Avatar
Ended up getting this sorted. FYI if anyone ends up in the same situation, the bolts are M14 70mm long, 2.0 screw pitch
Notching Rear Subframe ShutterSpeed Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 08-02-2020 09:27 PM
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
Tubular rear subframe Manji Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 09-24-2014 08:23 PM
MY15 Subframe bolt clunking emutcfut Issues | Warranty | Recalls / TSB 0 07-28-2014 02:29 PM
REVIEW | DC Sports rear subframe brace / rear subframe lateral brace mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-10-2014 08:59 PM
