Old 10-11-2015, 09:48 PM   #1
Carolina Dyno
Carolina Dyno's Avatar
Drives: 2013
Solid Aluminum Rear Subframe & Diff Bushings
This is a cross post but I know a lot of guys probably never check the FI section and these are probably actually more relevant here... We just finished test fitting our first production batch of solid aluminum rear subframe bushings. These are truly solid replacements for the rear subframe and differential bushings these are a tight press fit and completely eliminate bushing flex and differential movement. They also raise the subframe almost .25" which helps correct geometry on lowered cars. These are machined from billet 6061 T6 and anodized gold or black.
Also available in black
http://store.carolinadyno.com/produc...ntial-bushings
Carolina Dyno is offline   Reply With Quote
The Following 2 Users Say Thank You to Carolina Dyno For This Useful Post:
endless_pain (10-22-2015), RJasonKlein (12-29-2015)
Old 10-22-2015, 08:04 AM   #2
endless_pain
Pissin off regressives
endless_pain's Avatar
Drives: They have engines.
Any updates on the core exchange or the price for it?
endless_pain is offline   Reply With Quote
Old 10-22-2015, 10:00 PM   #3
Carolina Dyno
Drives: 2013
We're not going to list a core exchange option on the site but we have added the option for a complete subframe. We're pricing this at $1100 listed out below. For the forum guys only if you PM me first and we confirm your subframe is a good core (no hangers cut, dents, damage, NO crash history, etc.) we will refund you $300 on receipt of your subframe.
Solid Bushings: $400
Subframe: $300
Strip & Power Coat: $150
Install Bushings $250
http://store.carolinadyno.com/collec...ntial-bushings
Turn in Concepts (TiC) solid aluminum steering rack bushings review CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 08-14-2017 08:24 PM
New Solid Subframe Bushings - Install Pics Carolina Dyno Forced Induction 3 10-12-2015 03:29 PM
Solid Aluminum Rear Subfram & Diff Bushings Carolina Dyno Forced Induction 0 09-23-2015 11:39 PM
revolution garage rear subframe solid bushings review mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 07-01-2015 10:09 AM
options for solid rear subframe bushings? mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-26-2014 10:30 PM
