Drives: White Subaru brz
Fuel injector seals blowing out
Hey guys I got a 15 brz. I recently rebuilt the motor myself and since then I’m having an issue where my direct injector o-rings at the top of the injector blow out. I buy the seals from Subaru themselves. Have replaced the clips holding injectors in. Checked fuel trims and they check out okay. The fuel system is stock other than being tuned on e85. Any help would be appreciated thanks
friendly
Drives: 17' 86
pcv valve intact/working?
Seek comfort in discomfort.
I’m not 100% sure. How would I go about checking this
O-Ring part number wrong? Fuel rail installed wrong?
About the only 2 thing that could cause it. Doubt it is too much fuel pressure. |
16608JB010. I lube o-rings and slide the rail over the injectors then bolt it down. I figured it’s pretty much common sense with these but keep having issues. Thanks
Drives: 2018 BRZ
I replaced the orings about 6 times before I just bought new injectors with them already on. Didn't have a problem after that. I also didn't have the tool for the orings
Are you putting the o-ring back up on? Have you read the manual on installation procedures? Common sense does not always work if there are any unique installation procedures.
| Issues with direct injector seals, 2017 model | lwvyruz | Issues | Warranty | Recalls / TSB | 2 | 09-02-2020 07:47 PM |
| Another Direct Injector Seals thread | AndyBRZ | Engine, Exhaust, Transmission | 14 | 10-23-2018 06:22 AM |
| Is there a Subaru TSB for the direct injector seals? | armstrom | Issues | Warranty | Recalls / TSB | 5 | 06-13-2016 02:37 PM |
| do the direct injector seals need to be replaced? | Astroboy | Engine, Exhaust, Transmission | 17 | 04-15-2015 06:01 AM |
| Injector Seals went Bad while tuning my car | whitefrs | Forced Induction | 128 | 08-20-2013 12:19 PM |
