Old 09-13-2023, 11:43 AM   #1
Loganp98
Drives: White Subaru brz
Fuel injector seals blowing out
Hey guys I got a 15 brz. I recently rebuilt the motor myself and since then I’m having an issue where my direct injector o-rings at the top of the injector blow out. I buy the seals from Subaru themselves. Have replaced the clips holding injectors in. Checked fuel trims and they check out okay. The fuel system is stock other than being tuned on e85. Any help would be appreciated thanks
Loganp98 is offline   Reply With Quote
The Following User Says Thank You to Loganp98 For This Useful Post:
alphasaur (09-13-2023)
Old 09-13-2023, 12:00 PM   #2
alphasaur
friendly
Drives: 17' 86
pcv valve intact/working?
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 09-13-2023, 02:27 PM   #3
Loganp98
I’m not 100% sure. How would I go about checking this
Old 09-13-2023, 08:42 PM   #4
Grady
Grady's Avatar
O-Ring part number wrong? Fuel rail installed wrong?
About the only 2 thing that could cause it. Doubt it is too much fuel pressure.
Old 09-13-2023, 10:16 PM   #5
Loganp98
16608JB010. I lube o-rings and slide the rail over the injectors then bolt it down. I figured it’s pretty much common sense with these but keep having issues. Thanks
Old 09-14-2023, 03:23 PM   #6
MICHAEL450f
Drives: 2018 BRZ
I replaced the orings about 6 times before I just bought new injectors with them already on. Didn't have a problem after that. I also didn't have the tool for the orings
MICHAEL450f is offline   Reply With Quote
Old 09-15-2023, 10:22 AM   #7
Grady
Grady's Avatar
Are you putting the o-ring back up on? Have you read the manual on installation procedures? Common sense does not always work if there are any unique installation procedures.
Issues with direct injector seals, 2017 model lwvyruz Issues | Warranty | Recalls / TSB 2 09-02-2020 07:47 PM
Another Direct Injector Seals thread AndyBRZ Engine, Exhaust, Transmission 14 10-23-2018 06:22 AM
Is there a Subaru TSB for the direct injector seals? armstrom Issues | Warranty | Recalls / TSB 5 06-13-2016 02:37 PM
do the direct injector seals need to be replaced? Astroboy Engine, Exhaust, Transmission 17 04-15-2015 06:01 AM
Injector Seals went Bad while tuning my car whitefrs Forced Induction 128 08-20-2013 12:19 PM
