Old 08-30-2023, 07:24 PM   #1
Jozy
Jozy's Avatar
Drives: 2015 Subaru Brz Limited
Starter Replacement - Stripped Starter Bolt
Hey all, my starter went out. Started doing the work today following the YouTube guide posted on the forum. Seemed easy enough, then taking off the lower bolt that holds the starter in was a PIA! Came out crazy stripped and not sure how the damage is on the transmission / engine block.
I'm looking into using a tap but the ones I've seen don't seem deep enough. Can I even use a tap without dropping the transmission?
Would it be a terrible idea to just secure it with one bolt?
Kind of at a dead end at the moment. What do yall suggest?]
Jozy is offline   Reply With Quote
Old 08-30-2023, 08:23 PM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
What are the length of the bolts? It's possible the transmission has been out and someone put in a bolt that was too short. A longer bolt might catch enough threads to hold.
Old 08-30-2023, 08:34 PM   #3
Jozy
Jozy's Avatar
It's an M10 x 1.25 about 3in long below the head. I'm pretty sure its factory I ordered a set from the dealership.
I did have my clutch replaced about 3 years ago I'm thinking that's when it got cross threaded.
Old 08-30-2023, 09:10 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Drop trans and helicoil it. That hole is toast. Sorry.
Old 08-30-2023, 10:15 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
I died a little inside.
Old 08-30-2023, 10:36 PM   #6
Jozy
Jozy's Avatar
Been dead all day lmao
I was hoping there was an alternative but it's looking like dropping the tyranny might be the way.
I know a diy shop I can do it myself about 40 mins away from me.
Would it be dumb to hook up the new starter bolt it down with one bolt then drive out there to do the fix? I'm guessing it'd be fine but now I'm overthinking it a bit
Old 08-30-2023, 11:33 PM   #7
humfrz
Well, Bubba suggests you get a new bolt, smear it up good with Loctite (Red), screw it in there and see if it holds.
(well now, at first Bubba just wanted to weld the starter in place, but, I talked him out of that - )
Old 08-31-2023, 12:50 AM   #8
Ultramaroon
not playing cards
That's actually not a bad idea. One screw will be enough for a while. Don't go cinching it down extra tight.
"dropping the tyranny" haha
Here's how I keep the engine from flopping forward.
Old 08-31-2023, 10:26 AM   #9
Jozy
Jozy's Avatar
I've never fixed threads before. If I go that route do I need to up from a 1.25 to a 1.50 or what's the best way to go about that?
I looked into the heli coil and got even more confused ��
Old 08-31-2023, 10:27 AM   #10
WNDSRFR
Drives: FR-S,GTI
You could just leave the starter out and push start the car.
Old 08-31-2023, 10:42 AM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
10mm is the diameter. 1.25 or 1.5 is the pitch of the threads. So if the stock bolt is 10mm x 1.25 then you need a 10mm 1.25 helicoil kit. The kit usually comes with a tap and drill bit in the instructions along with the insert tool. I’d recommend looking it up on YouTube. Should be a “how to” or three on there.
Old 08-31-2023, 12:09 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Timeserts are also good. Just keep in mind it is really important you drill and tap the threads needed for the repair insert straight or you are going to have problems. Especially a bolt that long.
Old 08-31-2023, 12:34 PM   #13
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Just added a link to a knot diagram site in your engine strap thread.
Old 08-31-2023, 02:00 PM   #14
Ultramaroon
not playing cards
Yesss! Thanks!
Starter button gcranston Interior Parts (Incl. Lighting) 4 08-17-2022 02:13 PM
Starter swap? Wil Engine, Exhaust, Transmission 1 07-27-2016 07:50 AM
2013 BRZ replacement starter, correct part help sftateofmind Issues | Warranty | Recalls / TSB 25 07-21-2016 10:12 PM
ONR Starter Kits u/Josh Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 11-05-2013 11:47 AM
self-starter jarviz Engine, Exhaust, Transmission 16 09-14-2012 11:45 PM
