Drives: None
Gen 1 Fender to hub versus ground to pinch weld correlation
Does anyone know how pinch weld height and hub center to fender correlate with respect to the front of the car? I know fenders can vary, as well as how you call measurement points.
Previous owner mangled my front pinch welds (folded over and smashed the floor up) so I can't use them as a measurement point. Rear pinch welds are fine. As an example: Rear => 13.2" hub center to fender, 22.5" bottom of a 17" wheel, 5.125" / 130mm pinch weld to ground. I'm more or less trying to figure out what hub center to fender looks like for the ballpark of 120 – 135mm front pinch weld to ground on a Gen 1 with a 255/40/17 tire on a 17" wheel. I get that this is fuzzy math, trying to be in the ballpark. Looks like I got it way wrong with 21 7/8 bottom of 17 to fender on my car.
From bottom of pinch weld to top of fender I have ~20.25”-20.4”, my right front fender got dinged and thus sits about an eighth inch higher then the rest. Never wrote down hub center to fender as I can back it out with the info I have, and it’s annoying to measure accurately and with uneven fenders not really all that useful.
So if I have 5” at the pinch weld bottom edge, I’ll have ~25.25” at fender arch, which 24.7 wheel diameter means 13.05” from hub center to fender arch. This of course depends on how you measure your fender arch whether it’s from the bottom of the rolled portion or from the flat face which is another plus or minus an eighth inch. fwiw I’m 4.8” from bottom of pinch welds to ground, no rake, ~25” from fender to ground and thus ~12.7” from hub center to fender. That’s a 122mm ride height at the bottom of the pinch welds. Also, you’re not going to see a huge difference moving your punch weld measurement points back or forward a few inches, if it’s still intact by the wheels or near the door jams that should work just fine. |
| The Following User Says Thank You to strat61caster For This Useful Post: | RedReplicant (08-15-2023) |
Drives: None
Thank you, I appreciate it. They're mangled back to the doors, unfortunately.
I came up with 21.875" front and 22.75" in the rear measuring from bottom of 17" to fender. Front wheel measures 475mm lip to lip, so that gives me 12.5" hub to fender. Rear I got 5.125" / 130mm to the intact pinch, so that works out. Sounds like I got the front way too low, makes more sense now.
Drives: None
Actually, one more question, how much difference is there in wheel to fender arch or hub center to fender arch versus to pinch weld for front versus rear?
As in, how much lower does the rear fender sit than the front given the same ride height.
I have same front to back in my notes. Oem ride heights were a quarter inch higher in the rear iirc.
| The Following User Says Thank You to strat61caster For This Useful Post: | RedReplicant (08-16-2023) |
At the track
Drives: '14 FRS - Former e92 M3
I don’t have the differences, but I’ll add input that it’s easier to go off the fenders than the pinch welds for consistency’s sake. They have some variance, but if you compare them to thread distance from the perch on your shock bodies and corner weights you’re probably looking at closer accuracy within mom’s than pinch welds that are constantly getting beat up by jacks, curbs, etc.
I think I have some old notes somewhere I can PM to get you in the ballpark from hub-center to fender but they are in mm.
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
| The Following 3 Users Say Thank You to Kelse92 For This Useful Post: |
#7 | ||
Drives: None
| Pinch weld jack point protector | Pat | BRZ Second-Gen (2022+) — General Topics | 14 | 01-05-2023 01:14 AM |
| Pinch weld damage and repair | ...My Nine Rides Shotgun | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 09-06-2018 06:38 PM |
| Pinch weld side of the car bending! | Mikeez | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 10-22-2015 09:48 PM |
| Jack Stands + Pinch Weld | Wyattkb | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 10-12-2015 03:45 AM |
| protecting the pinch weld lifting points | midnitz | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-08-2013 09:36 PM |
