Old 08-12-2023, 08:55 AM   #1
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
Magnetic oil drain plug advisable?
At this rate it will into September to hit 1K miles and a first oil change. Along with getting oil and a filter, I've seen references here to magnetic drain plugs -- I do not think I've ever had one on any car. So, (a) if one is a good idea, which one to get and where (part # and/or link would be appreciated, or (b) does the car come from the factory with one?
1964 Sunbeam Tiger, 2015 Porsche Boxster, 2023 Subaru BRZ
tiger1964 is offline   Reply With Quote
Old 08-12-2023, 03:59 PM   #2
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
FuMoto valve. You're welcome.
If you NEEEED magnets, a nyodium one on the filter will do.
The Following 2 Users Say Thank You to bcj For This Useful Post:
soundman98 (08-12-2023), Spuds (08-21-2023)
Old 08-12-2023, 07:46 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
i ran one for a little while.
it gets 'muck' around it. does it save anything? who knows. more frequent oil changes also would save things.
after 3 oil changes, i got pissed off with it sticking to the metal oil pan on removal. it would stick just to the side of the opening, and then divert oil around wherever my drain pan is for the first 2 quarts until i could get enough expletives out, and an arm covered in oil to remove it fully to catch the remaining bit of oil.
i changed to a fumoto valve and haven't looked back. in 3 oil changes, the valve has literally paid for the amount of oil dry i was needing to clean up my mess...
Spuds (08-21-2023)
Old 08-12-2023, 10:41 PM   #4
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
They've been around a while, probably available for Ford Model T's. Never had one, does it impact sound clearance?
Old 08-12-2023, 11:31 PM   #5
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Stick with the stock plug. Works great.
AJ32162 (08-13-2023), soundman98 (08-13-2023)
Old 08-13-2023, 12:14 AM   #6
soundman98
soundman98's Avatar
not unless you're re-enacting starsky and hutch
here's the clearance to the skidplate
Spuds (08-21-2023)
Old 08-13-2023, 12:48 AM   #7
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Used to run a Fumoto. It got knocked loose at the racecourse, and I removed it.
I had a run-in with a rock on the road shortly after that. Thankfully it was removed, otherwise the rock would have ripped it off the oil pan
The only thing a drain plug magnet would protect is the oil pump. Magnet on the filter is redundant since the filter membrane will catch all the metal shards that enter it; as long as it's replaced at a normal interval, it shouldn't release any metal into the engine block
EndlessAzure is offline   Reply With Quote
Old 08-13-2023, 09:41 AM   #8
WNDSRFR
Drives: FR-S,GTI
And crush washers aren't needed. I've used the same "crushed" washer for the last ten oil changes and have never leaked a drop.
Old 08-13-2023, 10:14 AM   #9
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I reused the "crushed" washers on my trans and diff. No problems.
Magnetic plug? I don't remember iron filings listed on my oil analysis.
Old 08-13-2023, 10:38 AM   #10
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I bought a bag of them years ago. Worked out about 70¢ each.
Ultramaroon (08-13-2023)
Old 08-13-2023, 04:22 PM   #11
Ultramaroon
not playing cards
Ultramaroon's Avatar
Fresh gaskets and gentle torque on the plug are, in the long run, much better than repeatedly cranking down on a work-hardened one.
Old 08-21-2023, 03:47 PM   #12
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I've used a handful of various magnetic plugs on my WRX and BRZ. I will caution you against any cheap aftermarket plugs - especially with a magnet protruding far out into the oil a 1/2 or so. I've had one of these chunk off a piece and end up in the engine, filter, etc. Didn't do damage fortunately. It was a "Blox" brand, which isn't exactly a no-name eBay one either.
Subaru makes an OEM magnetic one that worked for my WRX. OEM and was a flat magnet. I run a Dimple brand magnet one that's essentially the same thing for my BRZ. Only real reason I changed it was the previous owner managed to start rounding off the OEM one.
I have seen some minor debris/buildup on it since installing. Like a silver metallic goo. It's common if you run a magnet. These very fine particles would likely be picked up in the filter eventually. It's kind of overkill.
I personally don't run a Fumoto valve because I autocross a lot. I could see it getting caught on a cone potentially under the car, even with the stock shielding under there. Maybe. Unlikely, but it's one less thing to worry about.
cmiovino is offline   Reply With Quote
Old 08-21-2023, 09:18 PM   #13
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I autocross with my fumoto valve with no issues. I have driven halfway across the country with a fumoto valve, no problems. I have done at least 12 oil changes with a fumoto valve (with a big-ole smile when I remember I have it and don't need to unscrew the plug), no problems.
The above again on my other car. Ok, I haven't autocrossed that... yet.
I do like them valves though.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
The Following User Says Thank You to Spuds For This Useful Post:
blsfrs (08-22-2023)
Old 08-22-2023, 10:06 AM   #14
WNDSRFR
Drives: FR-S,GTI
Yes I agree.
And you should change lug nuts every time you remove them.
Greddy Magnetic Oil Drain Plug + 10 Gaskets skylinekin Engine, Exhaust, Bolt-Ons 0 12-27-2017 04:21 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
Best magnetic drain plug? FR-Sizzle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 09-28-2015 01:07 PM
Magnetic oil drain plug, effective? BRZPDX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 02-16-2013 11:59 PM
Greedy Magnetic Drain Plug USMC -FRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 02-10-2013 06:04 PM
