Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 07-30-2023, 09:11 PM   #1
Tomyyyu
Drives:
GR86 - Throttle Body Cable Tore - Check Engine Code P2101
Got a check engine code. Was trying to install the oil pressure thing for a gauge and I made a big mistake.
Ended up tearing the cable (slightly) that goes into the throttle body. It looks to be single cable, not part of the whole cable diagram. Not sure, and need helping figuring it out. Attached the check engine code.
Tomyyyu is offline   Reply With Quote
Old 07-30-2023, 09:23 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
likely need to contact a junk yard and get the connector with 12" of wiring and re-splice it in with some heat shrink butt splices.
Old 07-30-2023, 09:29 PM   #3
Tomyyyu
Drives:
Might just put the original oil galley plug and take it to the dealer at that point.
Old 07-31-2023, 09:06 AM   #4
Joon525
Joon525's Avatar
Drives: 2016 BRZ
If you (I know it's in an uncomfortable spot) remove the intake inlet, temporarily replace the galley plug, and maybe move the ac compressor to the right you could proceed to de-pin the wire from the connector so you can repair it and then put it all back together.
The thought is that you'll have much more slack to make the repair to the single wire if it's not IN the connector.
Did it get damaged during the installation of the sensor?
Or did the wire rub against the sensor over time with vibration?
Joon525 is offline   Reply With Quote
Old 07-31-2023, 09:39 AM   #5
Tomyyyu
Drives:
During the installation. I made a mistake and I think I kinked one or two wires.
Big time rookie mistake
Old 08-03-2023, 02:49 PM   #6
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Confirm that the car has a CEL related to a permanent circuit malfunction and not a temporary malfunction. Clear the CEL and try to see if the code returns or if it does not return. If the code clears then return to the car and wiggle the wires with the car running to determine if the connect is stable or unstable. If the CEL does not return then you are okay. If it returns or if the CEL does not clear then move to the next step.
Confirm that the wire is damaged or loose. Exam the exterior for loose and severed wires. Remove the connector, and look inside the connector and see if the terminals are still in place or if they have been pulled back. If they has been pulled back then push the terminals/wires back in position. Give them a tug to see if they stay or if they are loose in the connector. If they are loose then you will likely need to repair or replace something in the connector or the connector itself. This isn't really that hard.
Every connector should have a clip or retention lock. These are either on the top/bottom of the connector that needs to lift up or hinge up, or there is a clip that needs to lift up on the inside of the connector. When you release the lock, the connector should separate and the wire terminals should freely slide out. You will likely see a terminal that is damaged or a wire that pulled free from the terminal. Your only option for a quick fix is that the hook or retainer tab on the terminal got recessed down into the terminal. If that is the case then use a small pick or screwdriver to lift the retainer tab up. Then slide the terminals back into the connector and lock the connecter and check for movement to see if the wire is still loose.
If a quick fix can't happen then purchase a replacement connector. If you have the space (harness length) and a crimping tool then you can just cut the wires at the end of the terminals, crimp new terminals and lock them into the new connector for an OEM look, but if you lack the harness length, tools to crimp terminals or skillset then you can just buy the pigtail and butt connectors.
Connector, connector with terminals, or as a pigtail, or pigtail with crimp connectors (4 options from the drop down menu)
https://iwireusa.com/products/electr...40734175559833
The other option if you lack the slack/length in the OEM harness to safely reach the plug without putting the harness in tension is to use an extension harness like the one below. Buy just the connector and terminals from above. You will then cut off the damaged connector, apply the new terminals and connector to the end of your OEM harness. Like I said, if you lack the length in the OEM harness, or if it is under too much tension, then you can buy the extension harness below and just plug it into your new connector and TB plug. Personally, if I could avoid a ball of six butt connectors tying two harnesses together then I would do that. If you go that route, I would suggest staggering the length of the wires, so you don't just have six butt connectors all terminating at the end of the harness in the same spot that becomes an inch size ball when you heat shrink them up. Just a suggestion.
Extension harness
https://iwireusa.com/products/dbw-th...body-extension
Old 08-03-2023, 03:23 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They are just going to replace the engine harness. I wouldn't doubt close to 1k in parts and labor.
Old 08-03-2023, 07:10 PM   #8
soundman98
soundman98's Avatar
yep, or $15 for a junk yard to clip the plug off, and $5 in heat shrink crimps...
Old 08-09-2023, 10:30 PM   #9
Tomyyyu
Drives:
I mean if the warranty covers it. Then yolo
Old 08-10-2023, 01:02 AM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
That's a pretty shitty thing to do. You fucked up. At least be a big boy and take responsibility for it.
Old 08-10-2023, 09:07 AM   #11
OkieSnuffBox
Drives: '23 BRZ Limited
You breaking the harness while messing around under the hood isn't going to be covered.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Check engine code P0441 Gibson Engine, Exhaust, Transmission 0 11-23-2016 05:39 PM
Weird noise from engine or throttle body allowe Engine, Exhaust, Transmission 21 10-12-2016 10:13 PM
Engine code 1264. Losing throttle control. Helpp Andrew360 Issues | Warranty | Recalls / TSB 4 09-08-2015 11:50 AM
check engine/CEL/DTC/MIL code list arghx7 Engine, Exhaust, Transmission 3 07-04-2012 10:37 PM
Check engine light code reader FRSCoupe Engine, Exhaust, Transmission 14 06-13-2012 05:06 PM
