Old 11-23-2016, 06:39 PM   #1
Gibson
Drives: 2013 brz
Check engine code P0441
I recently installed a new engine, and in the swap also added a dual catch can pcv system, and a supercharge. I did the EcuTek tune that came with the supercharge. The car runs great, and did for the first few hundred miles, then this P0441 code showed up. I thought it might be a loose gas cap, so i tightened that up, reset the code, but it came back on. Im not sure where to go next to see if i can figure out the problem. Any suggestions?
Gibson is offline   Reply With Quote
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 10:39 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 07:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
check engine/CEL/DTC/MIL code list arghx7 Engine, Exhaust, Transmission 3 07-04-2012 11:37 PM
Check engine light code reader FRSCoupe Engine, Exhaust, Transmission 14 06-13-2012 06:06 PM
