Old 07-03-2023, 02:19 AM   #1
ikeryder13
Drives: 2013 GBS BRZ
Another 15 fa20 swap
I am just trying to have a few questions answered.
I have a 13 brz that I am swapping a 15 JDM brz engine both manual trans.
1. If I have the 15 harness can I just use that?
2. Are there any other major things I need to change during the swap?
3. Is there any issues with the clutch or transmission that need to be addressed?
Thank you so much for the help guys
ikeryder13 is offline   Reply With Quote
Old 07-03-2023, 12:24 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes
No
No
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
alphasaur (07-03-2023), bcj (07-03-2023)
Old 07-03-2023, 03:17 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
technically on #3, if you're at/over 60k miles, or on the original throwout bearing, there's a revised version that's now out-- if you've got it out, i'd recommend changing it.
there's also the battlespace garage throwout bearing and verus clutch fork...
Old 07-03-2023, 04:31 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I guess I should elaborate that if you are using the 15' harness you need to use the 15' coil packs too.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
soundman98 (07-03-2023)
Old 07-03-2023, 11:38 PM   #5
ikeryder13
Does it matter if it's a JDM motor? Thanks everyone for your advice
Old 07-03-2023, 11:48 PM   #6
soundman98
soundman98's Avatar
i don't recall any difference regionally. just double check all the emission stuff is in place.
there is a difference between a manual and automatic car with a vacuum pump for the brakes on the auto's. not sure how complete your motor/harness is going to be.
Old 07-04-2023, 06:29 PM   #7
ikeryder13
It says everything but the transmission. I was considering getting. The transmission also but if its not necessary I won't spend the money
Old 11-04-2023, 07:22 PM   #8
ikeryder13
So I am finally about to do this guys. Can anyone let me know about the ecu? Can I use my 13 ecu? Also if I am using the 15 transmission will I need anything extra? Found a great deal on both combined
Old 11-05-2023, 01:44 AM   #9
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
So quick question.
Why did you get a "JDM" motor.
Was it super cheap as compared to a regular one? (since there is basically no difference between the two)
Or did you get suckered?
I ask because ALL of the blocks where I add "JDM" to it are hella overpriced.
And since you live in Cali according to your location.
A typical running good longblock is only like 2-2.5k max. A built one 4-5k.
This isn't the 90's and this isn't a B16/B18 where those people only wanted the "JDM" motors for the small bump in compression because the engines were so close in price where building and bumping the compression would usually end up costing more.
Old 11-05-2023, 03:16 AM   #10
ikeryder13
No I didn't get the JDM one. I just didn't know if it was preferred. I also wanted a 15 motor vs the 13 motor due to some of the recall issues that were bopefully fixed by that year. I have seen no long blocks that cheap. If you know someone who has one that has under 65k miles I would buy it. Out here even on Ebay everything is 3500 to 6k for that engine.
The Following User Says Thank You to ikeryder13 For This Useful Post:
x808drifter (11-06-2023)
Old 11-05-2023, 10:33 PM   #11
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Your original ECU is fine. No computers need to be changed
Nothing is appreciably different to the chassis if you have complete assembly with harness
EndlessAzure is offline   Reply With Quote
Performing FA20 swap with new FA20 Ctoner2653 Engine Swaps 8 09-24-2021 09:40 AM
Blown 2016 FA20 swap 2017 FA20 HRLQN Engine Swaps 11 10-15-2019 08:17 AM
Question on a WRX FA20 swap into a FRS Stoll_It317 Engine Swaps 6 07-27-2017 06:33 PM
FT: LS2 Swap for FA20 Setup Cross Engine, Exhaust, Bolt-Ons 4 03-24-2015 03:25 PM
WRX FA20 Swap? FT911 Engine Swaps 42 02-24-2015 06:49 PM
