Old 06-29-2014, 12:52 AM   #1
FT911
Drives: 2014 BRZ Limited CBS
WRX FA20 Swap?
So now that the WRX (and more) has a factory tuboed FA20. Would it be worth it to swap an engine from like a wrecked one in? If so would it be that difficult/expensive because they are the same engine? Just curious.
FT911 is offline   Reply With Quote
Old 06-29-2014, 12:53 AM   #2
ramiram1984
Drives: 2016 STi DGM
ima buy an impreza and put a wrx or sti engine in it...
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
The Following User Says Thank You to ramiram1984 For This Useful Post:
Choco (12-18-2014)
Old 06-29-2014, 01:58 AM   #3
horrorbiz
horrorbiz's Avatar
Drives: ‘22 BRZ Limited
It won't fit. The turbo would be too low.
horrorbiz is offline   Reply With Quote
Old 06-29-2014, 01:43 PM   #4
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Why not just buy a turbo kit at that point? A new fa20 engine from a wrx is going to be very costly. I feel like you can rebuild your engine and buy a turbo kit for the same price or less then a new fa20 from the dealer.
Sent from my XT1060 using Tapatalk
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
The Following 2 Users Say Thank You to WolfsFang For This Useful Post:
Bobblehead (06-29-2014), Dream20b (12-24-2014)
Old 06-29-2014, 04:55 PM   #5
Iand518
Iand518's Avatar
Drives: 2013 asphalt fr-s
I was also thinking this was a good option. Wouldn't dream of it for a couple more years, but a factory turbo motor would be very desirable. As people crash their WRX's engines will became available.
I have heard there are clearance issues, but I'm sure someone will solve them. Just wait, I bet anything we see this swap successfully done very soon.
Iand518 is offline   Reply With Quote
The Following User Says Thank You to Iand518 For This Useful Post:
RJasonKlein (03-04-2015)
Old 06-29-2014, 05:02 PM   #6
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
this thread has been covered many times already. The FA20DIT does not have PI injectors and uses a less sophisticated injection system that has already proven problematic in other platforms. The turbo is too low and the exhaust is on the wrong side of the engine. The advantages of this factory turbo are what? It has lower compression? buy pistons. it comes with a turbo? not a good one and the intercooler is on top.
Old 06-29-2014, 05:03 PM   #7
Reaper
Reaper's Avatar
Drives: violent
am I going to buy these and swap out the wastegate actuator, turn up the boost and stuff it into a buggy? you bet. But not into our cars and id still take an FA20 with a garret over it.
The Following 2 Users Say Thank You to Reaper For This Useful Post:
Dipstik-sportech (12-25-2014), Sam.Vera (02-03-2017)
Old 06-29-2014, 05:27 PM   #8
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Bellhousing is different. Wont bolt on.
Kostamojen is offline   Reply With Quote
Old 06-29-2014, 05:27 PM   #9
Reaper
Reaper's Avatar
Drives: violent
correct as well, starter is in a different location.
Old 06-29-2014, 05:59 PM   #10
FT911
Well it was just a thought. It's too bad though.
Old 06-29-2014, 06:33 PM   #11
Iand518
Iand518's Avatar
I stand corrected. Too bad.
Old 06-29-2014, 07:35 PM   #12
Calum
That Guy
Drives: 2013 asphalt FRS MT
This gets asked about once a week. To avoid the future frustration, would it be possible to sticky this?
The Following 4 Users Say Thank You to Calum For This Useful Post:
GT86_PRAGUE (12-30-2014), raven1231 (12-25-2014), SomeoneWhoIsntMe (06-29-2014), wparsons (06-29-2014)
Old 12-23-2014, 08:40 PM   #13
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Well apparently someone has done it and did it so well, that its virtually plug and play.
-Jack Burton
Old 12-24-2014, 09:08 AM   #14
Reaper
Reaper's Avatar
Drives: violent
Nope. And wrx guys are swapping our parts into their cars. Max hp on a di only wrx is 400hp without our PI. Starter is on the wrong side, exhaust is on the wrong side, turbo won't fit in the factory location, ecm/wiring harness doesn't swap over because of the canbus, intake manifold won't work...the list goes on.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
FA20 or 4U-GSE ??? WesFRS Engine, Exhaust, Transmission 2 04-25-2013 05:17 AM
VM vs FA20 CAi speedtrip Engine, Exhaust, Transmission 0 02-05-2013 01:34 PM
4UGSE/FA20 engine or swap? jordydiaz Scion FR-S / Toyota 86 GT86 General Forum 15 04-04-2012 07:00 PM
HKS s/c FA20?? Rome Scion FR-S / Toyota 86 GT86 General Forum 6 04-04-2012 01:13 PM
