Old 06-11-2023, 06:08 AM   #1
54fighting
Drives: 2020 toyota 86
Dipstick Reading With Oil Cooler
Just installed Jackson Racing oil cooler. Added an additional quart. Should the dipstick reading be higher than its "normal Range"?
54fighting is offline   Reply With Quote
Old 06-11-2023, 06:24 AM   #2
Ashikabi
Ashikabi's Avatar
Oil level in the pan"should" be the same with or without the cooler. Dipstick measures pan depth
Sent from my KB2007 using Tapatalk
Old 06-11-2023, 09:36 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
only if you're measuring after the vehicle sat overnight for the entire system to drain down.
checking after the motor is ran enough to build up pressure should result in a standard reading.
Old 06-11-2023, 01:11 PM   #4
KillerBMotorsport
KillerBMotorsport's Avatar
Shouldn't be he case if the oil filter's drain back valve is doing its job.
Easy enough to know, check cold and check after a startup.
KillerBMotorsport is offline   Reply With Quote
Idle MAP reading ~4psi but P3Gauge reading -20inHg FrickingReallySlow Software Tuning 6 10-08-2021 03:33 PM
Dipstick Inconsistency Jasper Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 04-13-2021 11:17 AM
BRZ oil dipstick level? indio22 Engine, Exhaust, Transmission 34 09-01-2020 07:54 PM
Dipstick question Qwimby2 BRZ First-Gen (2012+) — General Topics 26 11-27-2015 12:59 PM
Show me your dipstick.... Trashed675 Engine, Exhaust, Transmission 6 01-03-2014 01:09 AM
